Go to Post CAD or it didn't happen - R3P0 [more]
Unread 08-01-2008, 17:41
arpitshah arpitshah is offline
FRC #1514
arpitshah is an unknown quantity at this point
How to attach the Wheels direct to the transmition???
hey guys if u can help us out...
we wanna join the wheel directly to the axcel of the tranmition. however we donno how to join that wheel directly to the axcel. if u guys can give some ideas. that would be realyl gr8..
thanks a lot....and waiting 4 reply.....
Unread 08-01-2008, 18:14
AdamHeard's Avatar
Lead Mentor
Re: How to attach the Wheels direct to the transmition???
Are you reffering to the "Toughbox" that came in the Kit of parts?
If so, you might be able to mount a wheel on one of AndyMark's hubs and use a bolt into the tapped end of the shaft to secure it.
But, the transmission isn't really designed to have a wheel directly mounted to it...
Unread 08-01-2008, 18:25
DonRotolo's Avatar
Back to humble
FRC #0832
Google the term "Shaft Coupler". But, remember that the wheel spins on the axle, it's got bearings that allow the axle to stay still while the wheel spins. You'll need to take care of that, too.
Unread 09-01-2008, 19:47
FRC #1514
hey guys thanks a lot for ur replies. i really appriciate it...and ya the bearing point is a good point....thanks a lot again....
How do i attach pictures? Captain Thunder CD Forum Support 1 22-06-2007 16:56
how to attach a carrier plate for a turret arm to the robot. vivek16 Technical Discussion 11 18-04-2007 11:16
How do you drive the KOP 6" wheels? Alex Cormier Technical Discussion 7 04-11-2004 17:14
Direct 7.2v power from the wall... Ferazel2001 Electrical 1 31-01-2004 17:49
How do you attach a wheel to a shaft? SilverStar Technical Discussion 21 21-01-2003 19:52
