Go to Post Brandon, your amazing! CD media will rock my socks off more then DS&K! :p Ok, maybe I won't go that far. - Kyle Love [more]
Unread 08-01-2008, 18:20
jasonpeinko jasonpeinko is offline
FRC #1087
jasonpeinko is an unknown quantity at this point
Ifi loader and linux
I am running ubuntu on my laptop and am trying to get a loader program working with it, i have the compiler working but not the loader.
the loader runs under wine but when ever i try a hex file it says invalid hex file.
i have tried picloader but i have no idea how to use it with the usb to serial converter i am using.
Is there something that i should do to get it to work or am i better off using windows xp on a virtual machine?
Unread 08-01-2008, 19:02
HighLife's Avatar
HighLife HighLife is offline
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
Re: Ifi loader and linux
Hey Jason, picloader is probably your best option. I also have a usb to serial converter, just go into the directory with the FRC_Defalut.hex in it and run:
picloader FRC_Default.hex /dev/ttyUSB0
(/dev/ttyUSB0 is your usb convertor)
If you have any questions or problems just click the chat with an atombot button on adambots.com
or register at our forum and I'll help you out.
By the way pictools is the newest version of picloader. You can get it here.
AdamBots.com- Winner of 7 Best Website Awards!
Unread 08-01-2008, 19:44
FRC #1087
ok, i think it is that the driver is not loading right ill report back in a bit
Unread 08-01-2008, 20:15
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Last year I used a program called "rigel" to download the code from my Linux laptop to the robot, which worked fine for me. It was recommended to me by someone at an event the year before, but I don't remember who.
Unfortunately, nothing in the source for rigel seems to point me towards the distribution location, but a bit of searching on Yahoo found http://lights2dx.net/source/other/rigel/. (That other search engine did not find anything.)
I'd been using version 0.13, but it seems it's now at version 1.00-rc1.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 08-01-2008, 21:39
shtylman shtylman is offline
some sort of programmer
FRC #2420
shtylman has a spectacular aura aboutshtylman has a spectacular aura about
For the loader you can use a java clone of the IFI loader I created last year.
http://shtylman.com/jifi/
Get the latest version (should be at the bottom of the list) for whatever platform you need.
I have verified it to work with uploading the new 3.0+ compiler compiled code on this years controller
For the serial port issue you have to remove a certain program. What is happening (and this happens for all USB-Serial converters in ubuntu default) is that a program called brltty (braille tty terminal) takes control of the device and then disconnects it. What is why you can't use it. To fix the problem just sudo apt-get remove brltty and then plug the usb-serial converter back in and you should be set.
New C18 MPLab and IFI Loader? blaxbb Programming 5 06-01-2008 18:25
IFI Loader and PROG button Dave... Programming 3 20-02-2005 12:03
IFI Loader and MPLAB HolyOne207 Programming 5 14-01-2005 14:19
White Paper Discuss: IFI Loader for Linux with compiling instructions CD47-Bot Extra Discussion 1 09-02-2004 16:46
IFI Loader for Linux rwaliany Programming 7 08-01-2004 01:48
