Go to Post Try not to fall into the trap of choosing a material because it had the most supportive comments on CD. - Ty Tremblay [more]
Unread 08-01-2008, 18:16
MiniNerd24's Avatar
MiniNerd24 MiniNerd24 is offline
Are you going to eat that?
FRC #2039 (Rockford Robotics)
MiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the roughMiniNerd24 is a jewel in the rough
Smile Re: block thrown ball
Okay thanks Erich
The system is down.
Rockford Robotics 2039: Think outside the bots.
Unread 08-01-2008, 18:32
KoulFireChick's Avatar
KoulFireChick KoulFireChick is offline
Jack
AKA: Jill
FRC #1510 (Wildcats)
KoulFireChick will become famous soon enough
Send a message via AIM to KoulFireChick
ok I can't really say but I say not to do that. You don't want to afford breaking a part of your robot. That and you don't want to risk a penalty for unfair gameplay or another reason.
in robotics it's all about the "things" between the guys. When your a girl you're nothing more then a bistanderd forced to watch what really goes on during build season
Unread 09-01-2008, 14:34
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
What keeps a robot, with an arm, from turning around, after it crosses the opponents finish line, and knocking a hurdled shot back at the hurdling robot
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 09-01-2008, 14:45
Ragnarokae Ragnarokae is offline
AKA: Anthony
FRC #0967 (Linn-Mar Robotics)
Ragnarokae will become famous soon enough
HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
As long as you can hit the ball before it crosses the plane of the line, you are ok. Otherwise, it still counts as a hurdle if it touches your robot.
Eschew obfuscation.
"I never enter into a battle of wits with an unarmed person. Therefore, I cannot fight."
Unread 09-01-2008, 15:19
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
You can be above 6 feet now.
Unread 09-01-2008, 15:31
AKA: Anthony
I was thinking that if the ball crosses the plane of the line, then it would count as a hurdle. So if one can hit the ball away before it crosses the line, it would prevent the hurdle.
But if they hit it after the ball crossed, it counts as a hurdle per the definition of hurdle:
Emphasis added.
Eschew obfuscation.
Unread 10-01-2008, 07:15
AKA: Warthog
Do you think the refs will consider the ball the way they consider the bots? What I mean is robot has to be fully over the line before it counts for points. Since the finish line appears to be equal/past the far side of the rack the ball would not be across the line until it falls off the rack so you could knock it back.
What do you think?
Unread 10-01-2008, 07:24
GaryVoshol's Avatar
Cogito ergo arbitro
What do you think?
Since that is the definition of both hurdle and crossing, I think that is correct.
(since 2004)
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
What do you think?
Yes, Section 7.2 Definitions:
CROSSING: The act of a TRCKBALL or ROBOT passing through the plane defined by a line (i.e. LANE MARKER or FINISH LINE) when it is projected vertically upwards. A TRACKBALL or ROBOT shall have CROSSED a line when all parts of the object, while traveling in a counterclockwise
direction, have completely passed through the plane.
I was directed to this def. earlier when I asked whether or not the trackball must also move in a counter-clockwise direction, otherwise, I missed it.
Who has successfully THROWN ringers on to the rack yet? murray2077 Regional Competitions 108 01-04-2007 23:17
ball corral block, good or bad? Lil' Lavery Rules/Strategy 22 02-04-2004 23:35
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
2X Ball Into the Ball Release MikeDubreuil Rules/Strategy 23 28-03-2004 19:31
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
