Go to Post Most of our old robots have been scrapped for parts. Our Chairman submissions are still read every year by the whole team. - N7UJJ [more]
Unread 08-01-2008, 18:10
AdamHeard's Avatar
Lead Mentor
Keyed Aluminum shaft
Hi,
I'm trying to find 1/2" aluminum shaft with an 1/8" keyway. The problem is, so far only mcmaster has it at completely ridiculous prices. Anyone know a better place?
Unread 08-01-2008, 18:32
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
Re: Keyed Aluminum shaft
Have you thought about making your own? It doesn't take an advanced milling machine to make a perfectly decent shaft. Getting a broach and a means to press is an easy way to make keyed shafts.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 08-01-2008, 18:42
AdamHeard's Avatar
Lead Mentor
Right now I need about 5 feet of it. That'd take a long time to make on a mill.
but...... what is the process for keying shaft on a press?
Unread 08-01-2008, 18:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
There is none, as far as I'm aware.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2008, 18:58
AdamC's Avatar
Lathemeister
AKA: Batman
oy. For that kind of distance...I don't think you can. But if you're doing small lengths (<7") you can buy a broach, which is a serrated piece of metal that gets pressed across the surface of the shaft and cuts a keyway. By adding pieces of metal underneath the broach (we use sheet copper), you can increase the depth of the keyway. We made all our keyways on our prototype transmissions using a broach.
Unread 08-01-2008, 19:08
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Do you need one 5 foot piece? Or are you looking for more pieces that just total a length of 5 feet?
Unread 08-01-2008, 19:09
I wonder if Ed could tell you.
Unread 08-01-2008, 19:13
AdamHeard's Avatar
Lead Mentor
Right now I need 4 pieces about 14-15" long.
Unread 09-01-2008, 12:34
AdamHeard's Avatar
Lead Mentor
My mistake, I actually need 3/8" with 1/8" key. Makes it slightly less expensive on Mcmaster, but still more than I could stomach paying ($28 for 2 ft!!!!)
Unread 09-01-2008, 14:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
That really isn't all that bad when you consider it is 2024 (good stuff, stronger than 6061) and the time you'd spend machining in keyways.
Looking for a supplier of Keyed Aluminum Shaft ThorDiantral Technical Discussion 5 03-07-2007 19:20
Keyed Axles aznium Kit & Additional Hardware 4 03-02-2006 19:24
Matching a Gear to Keyed Shaft of DC Motor Spindle Motors 9 22-05-2005 20:23
5/8 keyed shaft trouble dddriveman Technical Discussion 14 18-05-2004 09:49
Big Shaft to Little Shaft? Anton Abaya Technical Discussion 7 21-01-2002 19:27
