Go to Post Fear the power of the custodians! - Fixen [more]
Unread 08-01-2008, 18:50
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Amount of tanks
You could do what 675 is toying with: A T-valve between the tanks and the pump. Add all 4 tanks. Charge in the pit, close T valve, disconnect pump (which ISN'T mounted to the robot), go to compete. As long as you have the regulation valve for the system at 60psi, you could charge the tanks at a higher pressure (we've been using 110psi for testing) which gives you more use out of the actuators.
Also, no mounted tank = Less weight and less power sap.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unusual amount of stickers Skifanatic Kit & Additional Hardware 1 10-01-2007 18:05
Amount of motors Windward Motors 1 16-02-2006 16:02
Amount of contact this year Ben Mitchell Rules/Strategy 18 02-02-2004 21:02
Maximum amount of stored energy? pryoplasm Technical Discussion 1 19-01-2004 20:57
