Go to Post FIRST is an organization that teaches students that smart is cool. - Warren Boudreau [more]
Unread 08-01-2008, 20:36
eyekantspel's Avatar
eyekantspel eyekantspel is offline
Autodesk Go-to-guy for build season
AKA: Derek
FRC #0011 (MORT)
Team Role: Student
eyekantspel is an unknown quantity at this point
Send a message via AIM to eyekantspel
Steering for mecanum?
For teams who have used a mecanum drive before or plan to use one this year, what are you planning to use as a controller to steer the robot? I had in mind a joystick, where the driver could twist the joy stick to spin the robot, push to the side to strafe, and any other combinations of movement.
Unread 08-01-2008, 20:44
qwertyuiop[]\'s Avatar
qwertyuiop[]\ qwertyuiop[]\ is offline
Drive Train/Manipulator Team Leader
AKA: Steven Harris
FRC #0623 (Cougar Robotics)
qwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of lightqwertyuiop[]\ is a glorious beacon of light
Re: Steering for mecanum?
i think that my team is considering a joystick with 2 buttons for spinning.
Unread 08-01-2008, 20:50
alicen's Avatar
alicen alicen is offline
Zebra Committee
alicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nicealicen is just really nice
joystick with 3 axis. twist the joystick = rotate the robot.
Unread 08-01-2008, 21:21
The TechnoKats built a simple Mecanum prototype a couple of years ago. Control is done with two joysticks and tank-style steering, but pushing sideways on the joysticks results in the 'bot "strafing" sideways.
It takes a lot of practice to control well, since there's no wheel speed feedback to keep the robot going in the desired direction without constant adjustment by the operator. With appropriate sensors and software, I think it would be very natural and easy to drive.
Unread 08-01-2008, 21:42
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
We used a 3-axis joystick for it. Rotation was used for turning like the post above. It was worked really well and we were able to use the full functions of the mecanum wheels nicely
Unread 08-01-2008, 22:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We have a mecanum promobot with a vex controller, and it uses a vex transmitter to control it...left joystick is direction control (left, forward, right, back, all relative to a driver "sitting on the robot"), right joystick controls rotation, left to rotate counterclockwise, right to rotate clockwise, with proportional control so you can rotate slowly, or quickly as needed.
Seems to be pretty easy to drive, could be improved upon?
Unread 09-01-2008, 20:41
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Our team last year used two joysticks- one joystick was tank drive, the other joystick used only the x axis and was for strafing only.This setup worked quite well, and we will probably be using the same setup this year.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 09-01-2008, 21:19
talltree357's Avatar
talltree357 talltree357 is offline
AKA: Joe Gro
None #0357 (Royal Assault)
talltree357 is a jewel in the roughtalltree357 is a jewel in the roughtalltree357 is a jewel in the rough
Send a message via AIM to talltree357
We have always used one joystick for steering mecanum drive. 2005 and 2006 were single joystick with the trigger used to engage translational drive. 2007 we used a 3 axis joystick, both work fairly well.
Unread 09-01-2008, 21:50
AKA: Bryan
We've been considering this, and so far we've come to the following conclusion-
One joystick, trigger to activate strafe results in a smaller control board, less joysticks to worry about, and more open ports for other things, but...
Two joystick (or three axis joysticks) allow for strafing while using tank drive, making it much more maneuverable.
So far, it looks like 2 joysticks will make a comeback for us, as it gives you more maneuverability, which really is one of the major reasons why we went to mechanum in the first place.
Unread 09-01-2008, 21:58
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I think Mecanum is pretty cool myself, and just want to know some more details about it even if it's not for this year.
That kind of drive concept intrigues me coming from a team who's only done tank or 4-6 wheel drives in the past.
I can't wait to see how teams do with the Mecanum drives a lot of them are talking about this year.
Does anyone have any sample code they used with a quick rundown of how it worked, or a list of hardware (both mechanically based and electrically based) needed for those interested in Mecanum drive?
This sounds like teams who have used this in the past could share a lot of insider knowledge this year, which is a cool concept in our world of sharing knowledge, and mentoring here in FIRST.
Code For Mecanum Wheels Adam Schuman Programming 26 27-07-2008 19:02
Looking for Mecanum Wheels Armando Gonzalez General Forum 30 24-05-2006 12:54
Mixing Joystick Values for mecanum wheels Leav Programming 10 15-01-2006 14:51
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
Gyrochip for Straight Steering, any tips? archiver 2001 1 23-06-2002 23:34
