Go to Post People don't lead because they are chosen to lead; they are chosen to lead because they lead. - EricH [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #76   Spotlight this post!
Unread 01-06-2008, 09:29 PM
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Re: 2008 Kit of Parts discussion
Eh, we're ditching the toughbox gearboxes this year and using the BaneBots CIM gearboxes again. We really liked how they performed in our bot, I especially like the low-profile design.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
  #77   Spotlight this post!
Unread 01-07-2008, 03:05 AM
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Originally Posted by Ricky Q. View Post
Not so fast on this one:
Originally Posted by 2008 Manual
<R59> Additional motors specifically permitted on 2008 FRC ROBOTS include:
All motors, actuators, and servos provided in the 2008 Kit Of Parts,
• HITEC HS-322HD servos,
• FIRST Tech Challenge (FTC) servos (Innovation First part number 276-2162),
• FIRST Tech Challenge (FTC) motors (Innovation First part number 276-2163),
• One or two additional 2-1/2” CIM motors (part #FR801-001 and/or M4-R0062-12 in addition
to those provided in the Kit Of Parts. This means that up to four, and no more, 2-1/2” CIM
motors can be used on the ROBOT.
According to this rule, you can use as many motors from the kit as you want, except for the 4 CIMs (think van door, window, globe, FP) .. this is significantly different from the same rule last year which didn't contain the "All motors, actuators, and servos provided in the 2008 Kit Of Parts" line.
Common sense tells me that this is a mistake, but maybe not?
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
  #78   Spotlight this post!
Unread 01-07-2008, 07:42 AM
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Has anyone noticed that the link provided in the KoP for the Taigene motor is broken? I am interested in this motor, as it seems to be the replacement for the big cim..
www.usfirst.org/frc_taigene
  #79   Spotlight this post!
Unread 01-08-2008, 05:44 PM
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
opened up the boxes today and omg... a little disappointed with the lack of parts this year. the packing crews seem to have been a bit lackadaisical with out boxes... 14 different pieces missing. does anyone know how the toughbox transmission is assembled? we followed the movie on andymark but the 7 year old just slipped a piece on and we sat there for two hours with a hammer trying to get that piece on to no avail.
also i notice that the kitbot chassis seems to have no inner structural support (bar in middle) like it had during the last four years. anyone have a clue where that went?
are the cim motors this year the same as the ones last year? because our team is lower on money this year so any parts that can be stripped off old robots are good.
  #80   Spotlight this post!
Unread 01-08-2008, 05:58 PM
Which part? Ours went together no problem.
It doesn't have one this year; the tranny braces form a triangle over the output.
Yes, AFAIK.
  #81   Spotlight this post!
Unread 01-08-2008, 06:40 PM
gondorf's Avatar
the part... the bigger bearing thingy that goes into the metal plate... tried both trannies and neither worked... both had same problem
  #82   Spotlight this post!
Unread 01-08-2008, 07:04 PM
OK, first off, there are two sizes. The smaller ones are the only ones that work in the lexan. Second, the bearings go on the shafts first. Note that they go on flanges down (if the lexan is on the bottom). Make sure the plate is put on with the large hole over the large bearing (which should be on the longer shaft).
  #83   Spotlight this post!
Unread 01-08-2008, 08:37 PM
in between teams
AKA: Luke Van Oort
Yeah, it should be easy to assemble. We built one in maybe 30mins tonight for prototyping and it went together pretty easy. We had some trouble with the roll pin (the vast majority of the time was spent on that actually), but on a whole there were an easy assemble. And they look cool! Those polycarb plates are pimpin'! BTW, if anyone else is having trouble with the roll pin, here's some advice: use a vise, it is really easy to bend the roll pin with a hammer.
Team 1219: 2009 - Mentor
  #84   Spotlight this post!
Unread 01-08-2008, 09:01 PM
gondorf's Avatar
the bottom ones went into the lexan fine, then the gears went in without a hitch. however when we went to put the big bearing (at least bigger than the ones that go in the lexan) on the shaft it got stuck about a quarter of an inch down the shaft. we hammered it and it still wouldnt go down. maybe the team just got themselves outsmarted by a 7 year old. the roll pin was easy once we stopped using kitbot metal as a hammer (as i said we are kinda poor) and borrowed a hammer from a guy in the neighborhood.
finger tightening kitbot bolts = doom to robot
well heading to bed maybe tommorow we will become "smarter than a fifth grader"
  #85   Spotlight this post!
Unread 01-08-2008, 09:19 PM
We almost had that. Wiggle it around a bit and make sure you get it straight.
  #86   Spotlight this post!
Unread 01-19-2008, 05:25 PM
Torboticsmember's Avatar
Torboticsmember Torboticsmember is offline
AKA: Alan Bartow
FRC #2080 (Torbotics)
Team Role: Driver
Torboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to allTorboticsmember is a name known to all
Originally Posted by vhcook View Post
You should have two large fans (P/N: 4112N/12GL-175) in the grey tote,
Does anybody know the dimensions for these because I am trying to get them down on a plan and don't have it here with me.
  #87   Spotlight this post!
Unread 01-19-2008, 05:38 PM
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
[the 4112 N/12GL Fans] because I am trying to get them down on a plan and don't have it here with me.
Measuring...
Outer Frame external dimensions - ~119mm across (both ways), 38mm deep.
Mounting Holes - Slightly over 4mm holes, ~105mm between hole centers.
Does that answer your questions?
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
  #88   Spotlight this post!
Unread 01-19-2008, 05:40 PM
AKA: Alan Bartow
Team Role: Driver
Yes thanks very much for the answer
  #89   Spotlight this post!
Unread 01-19-2008, 05:57 PM
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by edgar_amaro View Post
Hey!!! what is the distance between the floor & the bottom of the chassi
No specified distance - just be aware that there are bumps about 1/2" for plates that hold up the center structure.
& the floor & the bumppers supose to be
See Rule <R08>
(since 2004)
Autodesk Kit of parts Davie Byrne Inventor 5 01-09-2007 11:00 PM
Virtual Kit of Parts Madison Inventor 39 01-28-2004 04:49 PM
Parts dropped from the 2003 Kit of Parts? D.J. Fluck Rumor Mill 38 01-03-2003 07:29 PM
Starter Kit of Parts? Raul Robotics Education and Curriculum 2 10-29-2002 12:25 PM
