Go to Post Krispy Kreme and Diet Coke. Accept no substitutes! - dlavery [more]
Unread 08-01-2008, 20:28
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
AMPs for RC and Compressor
Hey Guys!!
Do you know how many amps we need for robot controller and compressor??
Thanks!!
Unread 08-01-2008, 21:51
Zack Briggs Zack Briggs is offline
FRC #0360 (The Revolution)
Team Role: Electrical
Zack Briggs is an unknown quantity at this point
Send a message via AIM to Zack Briggs Send a message via MSN to Zack Briggs
Re: AMPs for RC and Compressor
As far as I know, they will both run safely using a 20 Amp breaker.
Unread 08-01-2008, 21:58
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
The manual recommends running the compressor of a 20 amp breaker and the robot controller and <R55> states that the robot controller must be protected by a 20 Amp breaker. I know, you asked how much they draw. I don't know exactly, but I image the compressor draws around 10amps (probably more on startup) and the robot controller around 2.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 08-01-2008, 23:22
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
The RC, teathered to the OI sucked 600mA from the powersupply I ran it on today.
Unread 09-01-2008, 08:03
The RC is dynamic but the internals are voltage regulated and will shut down if the regulator is asked to supply more than 1.5 amps. However, the RC is the most critical component on the robot. Insure that power is connected to a point near the battery in you design and at a point where high current will not lower the voltage to the RC during match play. The RC will suspend operation when the voltage falls below 8 volts for a short period of time. During this time, the RC is powered by the backup but all outputs are inhibited.
The compressor start current is 25 amps while it's run current is between 10 and 12 amps. Due to the high start current for the this Spike only, electrical rules allow you to change the 20 amp fuse in the Spike to a 20 amp circuit breaker. Do it now so you won't forget. The fuse will burn open eventually.
Unread 09-01-2008, 10:31
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
I ran into that exact problem last year. We didn't have any problems with fuses blowing at our first two events, but by our third, we were blowing 20 amp fuses on the Spike every other match. After doing that a couple times, we switched to a 20 amp breaker, and all was solved.
Jeff Waegelin
Unread 09-01-2008, 23:44
beemgruem's Avatar
AKA: Begüm
So will I just use 20amps fuse on Circuit Breaker and don't use the Spike??
Or will I use both of them??
Thanks!
~Begum~
Unread 10-01-2008, 02:23
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
Thanks!
~Begum~
You want to replace the dumb yellow fuse on the spike with a 20 amp breaker. It will stick out and look a bit silly, but it's highly advised. Connect the spike to a 20 amp breaker on the breaker panel. So there are 2 20 amp breakers involved in the compressor/spike setup.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 10-01-2008, 02:25
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
I would use a spike, but replace the yellow 20 amp fuse and put in a 20 amp auto resetting fuse.
Unread 10-01-2008, 10:08
beemgruem's Avatar
AKA: Begüm
Thanks guys!!)
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
compressor and light question... archiver 2001 5 24-06-2002 00:47
