Re: Vacuum
Thats what I was wondering...
Re: Vacuum
Yes, the venturi generators from last year are legal as per Rule <R87>. However, they don't work in such a way that you could "pre-charge" a tank, when you open a solenoid valve letting air through them they create the vacuum, rather than having a "vacuum tank". In addition, those things are serious on the air usage, so if your going to use them for extended periods of time, you need the compressor on-board.
--NOTE-- We used them last year to pick up the tubes, worked pretty well, but the skin of that ball is going to be much harder to use vacuum cups on. |
Re: Vacuum
Still allowed... <R87>
For the purposes of the FIRST competition, a device that creates a vacuum is not considered to be a pneumatic device and is allowed. This includes, but is not limited to, venturi-type vacuum generators and off-the-shelf vacuum devices (as long as they are powered by provided or permitted motors). |
Re: Vacuum
I'd like to see one with only one point of contact on a Trackball that actually would work. I don't think it will.
The reason I say this, is because the fabric outer covering of the Trackballs will not result in a very good seal as the nice one layer vinyl tube would last year. If you tried this, you would probably need 2 or more on quite opposite sides of a ball, and in that case, why even bother adding the venturi mechanism when you basically have a gripper with 2 points of contact anyways? |
Re: Vacuum
Re: Vacuum
Vacuum can be used for many things besides picking things up.
If you can figure out a way to store vacuum in a sealed tank (think solenoid valves) and prevent the vacuum from 'leaking' out through the venturi (think timing of air supply), then yes, you should be able to store vacuum prior to a match, by "charging" the tank in the pits, sealing it up. Of course, this is merely my opinion, I cant say if it is legal or not, but this has been done by teams last year. Don |
#7
Re: Vacuum
thanks, thats what I thought, just trying to convince a mentor that it won't work...
#8
Re: Vacuum
A vacuum is not a pnuematic system. The solenoid rule clearly states that you can only use solenoid valves for pnuematics. Vacuum is not equal to pnuematics therefore solenoid valves used to contain the vacuum are not allowed. |
#9
Re: Vacuum
Re: Vacuum
Also you want to use vacuum solenoids not pnuematic. |
#11
Re: Vacuum
The next thing on the valves is the pilot control of a valve. valves require a air pressure to work. Just keep that in mind. Dont use a venturi! It is not enough use a bima cylinder on a fisher price motor. the rest you will have to figure out.
Has anyone tried to use a vacume on the nylon cover? Tell the success or failure, please. I am not sure how much leakage there must be to over come in volume. |
#12
Re: Vacuum
Peter, <R60> only talks about what parts are allowed to be on the robot. It says nothing about how they are allowed to be used. Whether the solenoids we are allowed to use will physically work for this application is up for debate, but please don't spread misinformation when the rules say something else.
#13
Re: Vacuum
Re: Vacuum
As it turns out, you are.
The rule you are quoting, <R60>, is forbidding electric solenoid actuators. It's not saying anything about legal or illegal ways to use pneumatic solenoid valves. Ironically, the parenthetical comment that is intended to clarify the meaning is apparently what's leading you to misinterpret it. Do you know what electric solenoid actuators are? They're the sort of thing that you find in chime doorbells, where an electric current causes a magnetic field to move a metal rod. |
| Vacuum Valve | Andrew Blair | Pneumatics | 14 | 12-03-2007 19:49 |
| Vacuum tube. | Eric Scheuing | Kit & Additional Hardware | 11 | 13-01-2007 14:04 |
| Vacuum Generator | Peter Matteson | Technical Discussion | 0 | 04-02-2005 15:58 |
| Vacuum | NoRemorse | Rules/Strategy | 25 | 22-01-2004 12:34 |
| Vacuum | nwagers | Pneumatics | 16 | 31-10-2003 15:57 |
