Go to Post I worship whoever cleans the robotics room. - John Gutmann [more]
Unread 08-01-2008, 21:56
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Vacuum
I know its legal to charge the pneumatic system prior to the match, but is it legal to create a vacuum or suction and store it in a tank prior to a match?
(We would plan on using the venturi generator from last years KoP)
Unread 08-01-2008, 21:58
Re: Vacuum
I think it would be very hard to do that. Also, is the venturi even legal this year?
Unread 08-01-2008, 22:00
AKA: Scott
Re: Vacuum
Thats what I was wondering...
Unread 08-01-2008, 22:15
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
Re: Vacuum
Yes, the venturi generators from last year are legal as per Rule <R87>. However, they don't work in such a way that you could "pre-charge" a tank, when you open a solenoid valve letting air through them they create the vacuum, rather than having a "vacuum tank". In addition, those things are serious on the air usage, so if your going to use them for extended periods of time, you need the compressor on-board.
--NOTE-- We used them last year to pick up the tubes, worked pretty well, but the skin of that ball is going to be much harder to use vacuum cups on.
Really, simpler is better; really, I swear
WHY DON'T YOU BELIEVE ME???
GearsOfFury's Avatar
GearsOfFury GearsOfFury is offline
Former guy that does stuff
AKA: Mark Anderson
GearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to behold
Re: Vacuum
Still allowed... <R87>
For the purposes of the FIRST competition, a device that creates a vacuum is not considered to be a pneumatic device and is allowed. This includes, but is not limited to, venturi-type vacuum generators and off-the-shelf vacuum devices (as long as they are powered by provided or permitted motors).
Unread 08-01-2008, 22:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Vacuum
I'd like to see one with only one point of contact on a Trackball that actually would work. I don't think it will.
The reason I say this, is because the fabric outer covering of the Trackballs will not result in a very good seal as the nice one layer vinyl tube would last year.
If you tried this, you would probably need 2 or more on quite opposite sides of a ball, and in that case, why even bother adding the venturi mechanism when you basically have a gripper with 2 points of contact anyways?
Unread 08-01-2008, 22:22
Droid Master
AKA: Bradley
Re: Vacuum
Kind of what I was thinking...
Unread 08-01-2008, 22:28
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Vacuum
Vacuum can be used for many things besides picking things up.
If you can figure out a way to store vacuum in a sealed tank (think solenoid valves) and prevent the vacuum from 'leaking' out through the venturi (think timing of air supply), then yes, you should be able to store vacuum prior to a match, by "charging" the tank in the pits, sealing it up.
Of course, this is merely my opinion, I cant say if it is legal or not, but this has been done by teams last year.
Don
Unread 09-01-2008, 13:32
AKA: Scott
Re: Vacuum
thanks, thats what I thought, just trying to convince a mentor that it won't work...
Unread 09-01-2008, 13:50
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Vacuum
Don
We did this in 2004 the only year it was technically legal. Note the solenoid use rule, R60, and the above quoted R87:
A vacuum is not a pnuematic system.
The solenoid rule clearly states that you can only use solenoid valves for pnuematics.
Vacuum is not equal to pnuematics therefore solenoid valves used to contain the vacuum are not allowed.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 10-01-2008, 04:06
Gchew Gchew is offline
FRC #0840
Gchew is an unknown quantity at this point
Re: Vacuum
Is a shop vac legal as a vacuum source?
Unread 10-01-2008, 04:37
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Vacuum
A Shop Vac contains a motor that is not FRC legal. If you can power it with an FRC legal motor the other parts of the Shop Vac are certainly allowed.
Unread 10-01-2008, 08:16
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Re: Vacuum
One thing to keep in mind with vacuum is that the forces you can create are rather limited unless you have little leakage or very high vacuum generating capacity. Recall that a perfect vacuum is by definition -1 atm relative to ambient pressure, which is approximately 14.7 psi, so to exert a lot of force, you need a lot of area, which in the real world usually means you have a lot of leaks. Assuming your vacuum storage tank and evacuation system are legal (I haven't looked into that aspect), you would probably need a pretty large tank if you plan to grip a leak-prone surface like the Trackball.
Pete Kieselbach
Unread 10-01-2008, 10:46
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Re: Vacuum
No comment on the legality of it ... but technically it'd be a challenge to convince me that it's worth the effort. We tossed that idea around for a little while during our brainstorming sessions, but it died off somewhat quickly.
For ball handling, with it's somewhat porous cover, the volume of air that you'd have to move would be huuuuge ... and the area of the suction cup would have to be pretty large. I don't think that a tank behind a solenoid would do the trick. I'd wager that you'd have to be constantly sucking large volumes of air to maintain a partial vacuum at the cup
If it's not for ball handling, then it's hard to comment on it's feasability. I suppose that there could be some use for a (partial) vacuum, but aside from ball handling, nothing comes to mind at the moment. ... other than an idea for next year's competition ... can anybody say Roomba-bots? Next year's trackballs could be dime-sized, and we'd have to gather as many as possible.
The regional winners get to travel to Mr. Kamen's house to help with his spring cleaning!
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 12-01-2008, 18:45
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Vacuum
Originally Posted by Peter Matteson View Post
Note the solenoid use rule, R60 [...] The solenoid rule clearly states that you can only use solenoid valves for pnuematics.
I'd venture that not only is that not clear, it's most likely wrong.
<R60> Items specifically PROHIBITED from use on the ROBOT include:
* Electric motors and/or servos different from, or in addition to, those in the Kit Of Parts, with the exception of those specifically permitted by Rule <R59>.
* Electric solenoid actuators (note: electric solenoid actuators are NOT the same as pneumatic solenoid valves – the latter are permitted, the former are not).
<R60> prohibits the use of electric solenoids, meaning electromagnetically controlled linear actuators. It notes that pneumatic solenoid valves, such as the ones found in the KoP, are legal. It makes no mention as to restrictions of their application... as such, you can use them in your pneumatics, you can use them as part of your end effector, you can use them as ballast, you can use them as non-functional decorations, and if you can make it work, you can most certainly use them to control a vacuum.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Vacuum Valve Andrew Blair Pneumatics 14 12-03-2007 19:49
Vacuum tube. Eric Scheuing Kit & Additional Hardware 11 13-01-2007 14:04
Vacuum Generator Peter Matteson Technical Discussion 0 04-02-2005 15:58
Vacuum NoRemorse Rules/Strategy 25 22-01-2004 12:34
Vacuum nwagers Pneumatics 16 31-10-2003 15:57
