Re: Pros & Cons of Carb/Swerve Drive Train.
Our mentor is an autotech teacher Last edited by team2061 : 08-01-2008 at 22:52. |
Yeah, as almost everyone else said, 4 wheels is probably best. Crab drive is heavy as it is; no need for extra wheels and weight.
What I've heard is a major problem with crab drive isn't so much the construction (although that's a task in itself) but the programming. You have to have sensors to make sure that all the wheels are pointed in the correct direction at the same time. Then you have to have a program to make sense of the data those sensors are sending to RC. All in all it's a tough job that probably should be started before the build season. |
| 6WD Pros and Cons | ChuckDickerson | General Forum | 59 | 13-01-2008 02:20 |
| Kitbot pros and cons | Jaybee1405 | Kit & Additional Hardware | 16 | 06-01-2008 23:57 |
| Two cameras: Pros and Cons | cooknl | Programming | 1 | 12-01-2006 20:57 |
| Motor Placement Pros and Cons | Pattie | Motors | 17 | 24-01-2005 15:40 |
| Practicing after Ship - pros & cons | Natchez | General Forum | 24 | 18-01-2005 23:06 |
