Go to Post So I guess this is just another case of someone reinventing the leg? - petek [more]
Unread 08-01-2008, 21:52
nekng's Avatar
nekng nekng is offline
Former 1836 Captain
AKA: Nate
FRC #1836 (MilkenKnights)
nekng is on a distinguished road
finish line flat?
Does anyone know if the finish line is flat? I am a bit confused, the rules say
"A red or blue “FINISH LINE” is marked on each side on the carpet under the OVERPASS. The
FINISH LINE is indicated by a six-inch wide tripe of black-and-white checkered tape, followed by a
two-inch wide stripe of colored gaffers tape. The pipes of the OVERPASS structure coplanar with
the vertical projection of the gaffers tape are colored to provide further indication of the plane of the
FINISH LINE. For the red FINISH LINE, the gaffers tape and pipes are red, and for the blue
FINISH LINE the gaffers tape and pipes are blue."
Does that mean the the line is flat or does it mean that there is a pipe that runs along the floor?
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: finish line flat?
I believe it is tape.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 08-01-2008, 21:56
The OVERPASS is 6.5 feet above the carpet. There are no pipes for it on the floor. It is marked so the plane of the finish line is clear.
Unread 08-01-2008, 22:29
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
As others have said, yes, the finish line is flat. The pipe is mentioned only to note that it is colored (even though its on the overpass) and over the finsih line.
Really, simpler is better; really, I swear
WHY DON'T YOU BELIEVE ME???
Unread 08-01-2008, 22:35
tkgamer's Avatar
tkgamer tkgamer is offline
AKA: Daniel E.
FRC #1388 (Eagle Robotics)
Team Role: Electrical
tkgamer is an unknown quantity at this point
Great our team was wondering the same thing. Thanks for the info!
Unread 08-01-2008, 22:41
Mrtrom Mrtrom is offline
AKA: Aaron Baker
FRC #0085 (BOB)
Team Role: Animator
Mrtrom is an unknown quantity at this point
the designs state that the finish line is 2 1/2 inches above the carpet
Unread 08-01-2008, 22:52
Imaginary Friend
AKA: Kevin Li
Team Role: Student
I don't think so. I don't see where it says that either.
Kevin Li
596 - Sciclones
Unread 08-01-2008, 22:53
Umm... I don't think so. If they do, then either Section 6 or the designs are wrong. Gaffers tape is not 2.5" thick.
I can't find that anywhere in the drawings.
Unread 08-01-2008, 22:57
Droid Master
AKA: Bradley
neither can I......
Unread 08-01-2008, 22:58
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
There's a difference between a 2.5" WIDE piece of gaffer's tape, and a 2/5" TALL piece of tape
2001-2004: Team 100
2006-Present: Team 254
Unread 08-01-2008, 23:28
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
The finish lines should be flat, but not the lane dividers:
Originally Posted by 6.2.3 The LANE DIVIDER
The LANE DIVIDER is attached to vertical posts that are anchored to supporting plates covered by carpet. Note that these plates will create a bump in the carpet approximately 1/2 inch tall, and as a result the surface of the TRACK will not be perfectly flat. ROBOTS must be designed to accommodate these surface variations.
Unread 09-01-2008, 00:20
nekng's Avatar
Former 1836 Captain
AKA: Nate
thanks that helps a lot.
Unread 09-01-2008, 01:04
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
That's what I always say
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
What is being described in that rule is the wall between the lanes, not the tape lines perpendicular to the driver station.
I'd treat the lines themselves pretty much as a normal surface, but if you need precision, it wouldn't be a bad idea to run your robot over the lines several times to determine if it makes any difference.
WPI District 2017 Volunteer Coordinator.
I'm not here to help.
Unread 09-01-2008, 07:16
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
The only 2.5" rule I can find is the height of the lower part of the bumper.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 09-01-2008, 07:28
Bethany Mc.'s Avatar
Bethany Mc. Bethany Mc. is offline
Fantasy FIRST Champion 2010
AKA: girl w/ the green fringe intertube/trackball dress
FRC #2996 (Cougars Gone Wired)
Bethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of lightBethany Mc. is a glorious beacon of light
Send a message via AIM to Bethany Mc. Send a message via MSN to Bethany Mc. Send a message via Yahoo to Bethany Mc.
One of MOE's mentors, and one student was invited to the kickoff in New Hampshire. We asked them this same question and they looked at the official field, and it was tape.
~*~BaM BaM~*~
19th Annual Del Tech Drafting Winner 2008 in Inventor!
Robo Prom Queen 2008- thanks 399
Attending 2011:
Florida
St. Louis
Quick clarification regarding crossing the finish line MNov Rules/Strategy 18 06-01-2008 18:06
Flat Scren Displays rcubes85 General Forum 13 20-08-2006 09:44
The World is Flat Beth Sweet Chit-Chat 0 23-10-2005 22:16
Finish that line Aaron Lussier Chit-Chat 75 14-07-2002 08:58
