Go to Post Is it weird we think speed controllers are sexy? - vivek16 [more]
Unread 08-01-2008, 16:17
m1k3 m1k3 is offline
FRC #1396
m1k3 is an unknown quantity at this point
Amount of tanks
if your operating 3 pistons how many tanks of air should you use?
Unread 08-01-2008, 16:23
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Amount of tanks
How big are the pistons you're using? The 3/4" bore 1" stroke cylinders used in the AM shifters take a whole lot less air than the 2" bore 24" stroke behemoth from Bimba.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 08-01-2008, 16:25
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Talking Re: Amount of tanks
This is a difficult question to answer because we don't know what size cylinders you are going to use, and how much you are planning on using them. If you only plan on actuating the cylinder once, then you need to figure out how much volume of air is required to fill the cylinder at 60PSI and you can calculate the volume of the storage cylinder. Some small amount of calculations later you can find out how many storage cylinders you need. Now the rules state that you can only have 4 storage tanks (identical to the 2 supplied in the kit of parts) - refer to The Robot section, <R84>.
If you need more air, then it is time to start thinking about including the compressor on your robot. Then you might be able to reduce the amount of storage cylinders you have depending on how often you want to use your cylinders during a match.
Hope this helped!
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 08-01-2008, 16:31
caraddicted101 caraddicted101 is offline
caraddicted101 has a spectacular aura aboutcaraddicted101 has a spectacular aura about
Re: Amount of tanks
Hope this helped!
I agree with him, it is hard to know the amount of tanks that you would need. I would say to mock up a pneumatics set up and fire the cylinders that you have and look at the psi loss on the tanks as you fire the cylinders. One thought is to put multiple regulators on your system to save air as some applications do not need the full 60 pounds of pressure. Putting more regulators on could possibly save your from putting on that extra tank thus saving you a little room and a bit of weight.
- It's a thought
Unread 08-01-2008, 17:55
etphonehome etphonehome is offline
FRC #0537
etphonehome is an unknown quantity at this point
Re: Amount of tanks
i would use all 4 storage tanks unless you have a major weight problem
if you're extending/retracting your pistons a lot the air gets used up fast
and the air compressor really drains your battery, so you want to have lots of air stored
Unread 08-01-2008, 18:31
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Amount of tanks
just add all 4 of em just make sure you could take one out if you need to loose weight.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 08-01-2008, 18:50
Otaku's Avatar
Otaku Otaku is offline
Where'd my wrench go?
AKA: Michael Baker
FRC #0675 (Tech High Phantom Robotics)
Otaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond reputeOtaku has a reputation beyond repute
Send a message via AIM to Otaku Send a message via MSN to Otaku
Re: Amount of tanks
You could do what 675 is toying with: A T-valve between the tanks and the pump. Add all 4 tanks. Charge in the pit, close T valve, disconnect pump (which ISN'T mounted to the robot), go to compete. As long as you have the regulation valve for the system at 60psi, you could charge the tanks at a higher pressure (we've been using 110psi for testing) which gives you more use out of the actuators.
Also, no mounted tank = Less weight and less power sap.
"The [Otaku] is a simple creature." "Indeed. I cease to function when removed from a mill."
Unread 08-01-2008, 19:50
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: Amount of tanks
Be sure to check the rules closely before doing this. In recent years, they've been making it harder to do this. I don't know what the rule is this year, but last year the rule was that everything had to be on board the robot, except for the compressor itself. That means all the plugs for powering the compressor, the sensor, the spike, etc. The software had to control turning the compressor on/off. Also, be sure that you have no leaks in your system. This is especially important if your compressor is off-board.
As long as you're not using too much air, I think it's a good idea to have the compressor off-board, to save weight. Two years ago(?) we used pneumatic shifters, which were the only pneumatics on the robot. It used two of about the smallest cylinders available, and two air tanks. This was plenty for us for a match.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 08-01-2008, 22:52
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Re: Amount of tanks
Depends on how much you'll use your pneumatics. If its only a few time a match you might be good with two. But if it is constant you might want one OR two AND a compressor aboard. Overall it comes to usage. If you know you won't even use two tanks, put three to be safe. Worst come to worst how many time a match will you use your pistons and prepare for the answer to that question. I suggest though a compressor and one or two accumulators though.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 08-01-2008, 23:03
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
Re: Amount of tanks
Just to echo what everyone else is saying, to me (and I know how the "we need to shave off just .1 lbs. AHHHHHH) you should always put all four tanks on (you never, EVER, want to run out of air, its really not very fun, so you should play it safe) and if you're going to be using the pneumatics for, say something like scoring, you need to put the compressor on too; because that air will be gone really fast (note last comment about running out of air)
Really, simpler is better; really, I swear
WHY DON'T YOU BELIEVE ME???
Unread 08-01-2008, 23:45
Steve Kaneb's Avatar
Steve Kaneb Steve Kaneb is offline
That's what I always say
AKA: Alex
FRC #0190 (Gompei and the H.E.R.D.)
Steve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really niceSteve Kaneb is just really nice
Send a message via AIM to Steve Kaneb
Number of tanks relates to how often you use them.
Last year, we had a compressor and 2 accumulators. Our robot used a piston to actuate the gripper (4 or 5 times a match) and 3 pistons to actuate each wing (once a match).
If your system won't be actuating many times a match, you should figure out how much air pressure you're using each time, and base how many accumulators you need on that. A compressor may be unnecessary depending on the amount of air you're spending a match.
Losing the compressor is a significant chunk of weight, so I suggest figuring out whether you're going to need to refill your accumulators.
WPI District 2017 Volunteer Coordinator.
I'm not here to help.
Unread 09-01-2008, 07:53
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: Amount of tanks
Give someone a fish, and they can eat for a day. Teach them to fish and they will eat for a lifetime. I’m going to answer the question I’m sure you meant to ask, which is “How do I determine how many tanks to use based on my selected actuators (pistons) and their usage?”
First some background you need to understand:
  1. The volume of each tank is pi x (diameter/2)^2 x length. The volume of air used in each stroke of the actuator is pi x (diameter/2)^2 x stroke. It uses that volume each stroke, both extending and retracting.
  2. Since all the volumes are linear functions of pi, you can take it out of the equation to simplify the calculations. (make your volume unit in^3/pi)
  3. The pressure on the gage is the gage pressure (duh), which means the absolute pressure minus ambient pressure (about 14.7 psi for a standard atmosphere). This is the pressure used for force calculations (and the regulator settings).
  4. From ideal gas laws, pressure x volume is a constant for some amount (mass) of air. In this case the pressure is the absolute pressure. So 100 in^3 of air at 60 psi absolute is the same amount of air as 200 in^3 of air at 30 psi.
  5. You can fill the tanks to 120 psi. The maximum pressure allowed to actuate the actuators is 60 psi (the setting of the fixed regulator), which you will probably use for pushing or forcing a mechanism. To position something (like shifting gears in a gearbox or opening/closing against a stop that will take the load) 20-30 psi will probably be OK. You’ll need to use the extra regulator to set that pressure.
  6. Each stroke of an actuator uses some amount of air from the tanks, which causes the remaining air in the tanks to expand and fill up the volume. This reduces the pressure in the tanks. You can continue to do this until the tank pressure drops to the operating pressure you need to operate your actuator.
  7. The air in the plastic tubing is additional volume used for each stroke but it is very small compared to the actuator so we’ll ignore it.
So here (finally) is how you do the calculations:
For each tank, d=2.0, L=6.0, volume = 6 in^3/pi (at 120 psi). Suppose you want to run your actuators at 60 psi; the amount of air in each tank is equivalent to 6 x (120+14.7)/(60+14.7), or 10.82 in^3/pi at 60 psi. You will leave 6 in the tank – after that the pressure will drop below 60 – so you have 10.82-6=4.82 in^3/pi usable air at 60 psi.
Suppose you are using ¾ inch bore actuators. That’s 9/64 or .14 in^3/pi per inch of stroke. So each tank gives you 4.82/.14=34.27 stroke inches. For a 4 inch stroke actuator, that’s 8 strokes, or 4 cycles (extend and retract = 1 cycle)
Now suppose you are using 1-1/2 inch bore actuators. That’s 9/16 or .56 in^3/pi per inch of stroke. So each tank gives you 4.82/.56=8.56 stroke inches. For a 4 inch stroke actuator you will get 2 strokes (1 cycle). For the 2 inch bore actuator, it is 1 in^3/pi per inch of stroke. So each tank gives you 4.82 stroke inches, and you can only get 1 stroke out of a 4 inch stroke actuator.
Now try running the actuators at 30 psi. Using the calculations above at 30 psi, usable air in the tank is 12.08 in^3/pi at 30 psi. Scaling by 12.08/4.82, you get about 2.5 times as many cycles per tank.
You should be able to use the information for different combinations of pressures and actuators. I usually put it in an Excel spreadsheet so I can see the sensitivity to different changes. Good Luck.
Unusual amount of stickers Skifanatic Kit & Additional Hardware 1 10-01-2007 18:05
Amount of motors Windward Motors 1 16-02-2006 16:02
Amount of contact this year Ben Mitchell Rules/Strategy 18 02-02-2004 21:02
Maximum amount of stored energy? pryoplasm Technical Discussion 1 19-01-2004 20:57
