| Thread Tools |
Rating:
Display Modes |
#136
Re: New C18 3.0+ Compatible FRC Code
Just grabbed both 2.4 versions and opened them up with MPLAB 7.62. I only had two issues.
1) The ifi_frc_8722_25.lib file was being displayed as "Not Found" even though it was in the root directory of the project along with all the other files. I just removed the "Not Found" version and added it back in the project. 2) Error during linking saying that the CLIB.LIB wasn't found. It was looking in c:\program files\mplab\mcc18\lib instead of c:\mcc18\lib. Very likely a configuration mistake on my part here. I just went in to the project properties and added the correct library path. Compiled and linked without any errors. Nice work Kevin. Sean |
#137
-Kevin |
#138
Thank you very much. I'll hopefully be able to provide gyro and encoder code feedback soon.
#139
I've finally been able to compile the 3.1 code, so I started looking over it. It seems that it's a lot cleaner than the past few years' code, but I'm used to those, so I've got a few questions. In the past few years we just put our processing of inputs on the joysticks in Default_Routine(). (This is probably not the best way to have done it, but oh well) I'm assuming we should put all of this code such as using the buttons and stuff into Teleop()? Thanks for the help, great code!
-Arty |
#140
Kevin:
In your beta code 3 you have two definition for timer 4, one in the timers.c with its ISR in interrupts.c and a 2nd in the adc.c code again with its ISR... this maybe confusing for user... thanks... ps: there are a few typo still in ADC code, ie label is timer 2, but your code is timer 4... |
#141
I just spoke with the programming team tonight. We had to decide between EasyC Pro, MPLAB and IFI default code and the newer MPLAB and compiler with Kevin's new build.
I am happy to say, 2073 will be stretching their skills and using the new code and compiler. Now I have a dilemma. The team does not have access to a laptop, plenty of computers, but no laptop. So, they will have nothing to take with them to competition. I will not be able to join them at our regional either because of a previously arranged vacation in Hawaii. I do have a laptop I am willing to let them borrow, but it currently has my personal copy of MPLAB 7.2 and C18 v2.4 on it that I use with my personal Vex kit. I prefer not to uninstall it if I can avoid it. So, the question is, can MPLAB's 7.2 and 8.1, and C18's v2.4 and v3.1 co-reside on the same system? |
#142
-Kevin |
#143
-Kevin |
#144
-Kevin |
#145
Excellent! Got it running!! Next question. You currently have 3 versions for 3.0: Basic, Basic + Gyro, Basic + encoders. To add the encoders to the basic + gyro, do I just add the encoder.h/c files to the project? Then follow your instructions for adding your encoder code from an earlier build, like 2007's ifi_encoder.zip? |
#146
1) Adding encoder.c/.h to the project. 2) Putting #include "encoder.h" at the top of each source file where any encoder functions will be called. 3) Calling the encoder initialization function(s) from teleop.c/Initialization(). 4) Enable the individual encoder channels at the top of encoder.h. 5) Assign the encoder phase b signals to digital inputs at the top of encoder.h. 6) Enable the interrupt(s) associated with each enabled encoder channel at the top of ifi_frc.h. 7) Make sure there are no conflicting ISRs enabled at the top of interrupts.h. 8) Compile and test. -Kevin |
#147
Kevin,
Did anything turn up on your inspection of the provided code with respect to a possible source of the 8.3 volt bug? With all the interrupts we will have flying this year, we are sweating it, although we will get a good six weeks to see if it surfaces again. Eugene |
#148
If it's of any interest, I did notice the new code and compiler seem to handle high interrupt loads better than with the 2.4 compiler. I setup my ADC code to sample at 6400Hz (each sample generates an interrupt) while generating a few hundred more interrupts/sec with a encoder. The RC had no problems sending a bunch of telemetry using printf() under the load. -Kevin |
#149
Awesome, thanks a lot Kevin!
| Does the camera code suits to all versions of MPLAB and C18? | razer | Programming | 3 | 04-01-2007 14:50 |
| Trying to follow C18 interrupt context code... | dcbrown | Programming | 5 | 21-12-2006 09:01 |
| Error w/ FRC code | JamesBrown | Programming | 2 | 08-01-2005 16:17 |
| Programming code Fix FRC | Ferazel2001 | Programming | 6 | 08-02-2004 02:46 |
| FRC default code | hedgehogger | Programming | 2 | 21-01-2004 18:41 |
