#31
Re: How to get the ball over the overpass!?
If it is potentially unsafe, I don't think that the robot would pass inspection. In addition, depending on where said latch is, it would probably constitute an illegal modification to the pneumatics circuit and/or components. Without explicit permission from FIRST, I wouldn't reccomend that approach on any robot.
#32
Personally, the forklift seems like the best idea to me
Pneumatics, Springs Pros: Faster, and they may fit in the minimum size dimensions (no need to unfold) Cons: You'll need a LOT of energy to launch a 10 pound ball 6 feet in the air. The springs to do this would have to be huge, and I doubt FIRST would allow it. Also, how would you reload the springs for more than one hurdle? Catapult Pros: I can't really think of any... Cons: It would have to be huge to get enough leverage to launch a ball, so it would involve some serious unfolding to get out of the minimum size box. Also, when you do have it unfolded, moving would be problematic. Forklift Pros: There aren't very serious cons xD Cons If it becomes top-heavy, your robot could tip. Pay attention to balance. |
#33
#34
![]() The catapult itself need not be very large, as long as there is some structure on the robot that will hold the ball in position, such as rails or bars that it can rest on. The catapult only needs to be a couple feet long. We have been using energy calculations to study the feasibility of various catapult designs, I think they figured it would take about 80 or so Joules to launch the ball over the overpass. Next design we're working on involves a motor, with a flywheel type gizmo with a connecting rod that actuates the catapult. It would be a relatively low speed device that would not need to make more than one revolution per launch, I think. Fun stuff....we're discussing a few of these ideas on our N.E.R.D.S. forum too. |
#35
What we did was take a 2" bore, 2' (about ish) stroke cylinder and cover up the air port nearest the piston, then we pressurized the other side to 60 psi. The piston extended out about 16" and stopped. We then removed the cover (thumb) from piston side port and the piston shot out with a resounding CLANG!!!! (In otherwords a GREAT deal of force.) But the reason why our mentors questioned the legality is the little FIRST rule that states that, you cannot compress air in "non-Clippard" containers. I have asked an alum, and have yet to hear back. Now I'm curious as to what the FIRST community has to say. |
#36
an idea that was thought up by my team was to use a holder underneath the track ball, make the holder go up or down in angle, then have like a pneumatic bulldozer bar shoot out and almost kick it over or shoot if you prefer.
#38
We're planning on using telekinesis.
#39
Hmm, can you prove that's a legal power source? As long as you don't use gerbils, I suppose it passes the flowchart.
#40
Trebuchet?
#41
1885 is considering using the power of steam, so we're looking into building a great big pot with boiling water beneath a "cannon". It will be complete with a pressurization chamber and several parallel tubes since the durn things are so tiny. We'll also have some 2" Bose speakers on the right side of our robot pointing to the crowd that will play a nice BOOM whenever the ball is shot. Vintage late 1800's
![]() No, I'm not serious |
#42
Well you think with over 16 years in the business some form of mutation would show up. That or it's a particularly potent form of geekiness.
#43
How about dribbling the ball from below. As you drive around you start bouncing the ball straight up in the air. You only have to add a small amound of energy with each bounce thus everything would be quite safe. With each bounce it gets higher and higher and as you pass under the overpass you stop the robot and the ball keeps going. Then you run under the ball and catch it for the next lap. I think a robot that can dribble would definitely earn your team some kind of technical award.
#44
I can smell the Einstein gold already... |
#45
our team is considering the forklift + electric actuator design.
We would forklift the ball atleast 3' above the ground and use the actuator to hurdel the ball over the overpass... of course balance is crucial in this case, but if we tilt fork lift so it would form a right triangle from the back of the robot of the front, all the weight will be on the center of the bot rather than the front... what do you think?? |
| Throwning the ball over the over Pass | eastsideboma | Rules/Strategy | 16 | 01-15-2008 12:56 PM |
| How do you get your other ball | Jeff 801 | Rules/Strategy | 80 | 01-07-2008 05:59 PM |
| pic: Dimensions of the Trackball on the Overpass | Bethany Mc. | Extra Discussion | 2 | 01-07-2008 09:01 AM |
| How to filter the points to get only the left most and right most? | tommy_chai | Programming | 2 | 11-28-2007 11:39 AM |
| Height of the bar over bonus ball structure | punarhero | General Forum | 3 | 01-17-2004 02:39 PM |
