Go to Post More teams will want to join, peers who are not on the team will understand the program better, television will become interested in FIRST again, sponsors will be easier to get, cancer will be cured, the Israelis and Palestineians will live in harmony, and we will have world peace. - Andy Baker [more]
  #31   Spotlight this post!
Unread 08-01-2008, 23:42
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
Re: How to get the ball over the overpass!?
If it is potentially unsafe, I don't think that the robot would pass inspection. In addition, depending on where said latch is, it would probably constitute an illegal modification to the pneumatics circuit and/or components. Without explicit permission from FIRST, I wouldn't reccomend that approach on any robot.
Really, simpler is better; really, I swear
WHY DON'T YOU BELIEVE ME???
  #32   Spotlight this post!
Unread 08-01-2008, 23:50
marypim's Avatar
marypim marypim is offline
FRC #1899
marypim is an unknown quantity at this point
Personally, the forklift seems like the best idea to me
Pneumatics, Springs
Pros: Faster, and they may fit in the minimum size dimensions (no need to unfold)
Cons: You'll need a LOT of energy to launch a 10 pound ball 6 feet in the air. The springs to do this would have to be huge, and I doubt FIRST would allow it. Also, how would you reload the springs for more than one hurdle?
Catapult
Pros: I can't really think of any...
Cons: It would have to be huge to get enough leverage to launch a ball, so it would involve some serious unfolding to get out of the minimum size box. Also, when you do have it unfolded, moving would be problematic.
Forklift
Pros: There aren't very serious cons xD
Cons If it becomes top-heavy, your robot could tip. Pay attention to balance.
  #33   Spotlight this post!
Unread 09-01-2008, 00:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
It's not as bad as Matt suggests....there is some cushioning as the cylinder reaches full travel (it has to compress some air on the top side of the piston as it reaches full extension, because of how the valves work). And the catapult mechanism could be safely enclosed in the robot, with adequate protection around it.
No modification of the cylinder is necessary, since the latch is on the lever that the cylinder actuates.
  #34   Spotlight this post!
Unread 09-01-2008, 00:12
MrForbes's Avatar
AKA: Jim
Originally Posted by marypim View Post
Catapult
Oh, you just need to spend more time thinking about it
The catapult itself need not be very large, as long as there is some structure on the robot that will hold the ball in position, such as rails or bars that it can rest on. The catapult only needs to be a couple feet long.
We have been using energy calculations to study the feasibility of various catapult designs, I think they figured it would take about 80 or so Joules to launch the ball over the overpass.
Next design we're working on involves a motor, with a flywheel type gizmo with a connecting rod that actuates the catapult. It would be a relatively low speed device that would not need to make more than one revolution per launch, I think.
Fun stuff....we're discussing a few of these ideas on our N.E.R.D.S. forum too.
  #35   Spotlight this post!
Unread 09-01-2008, 01:30
silicon_ghoti's Avatar
silicon_ghoti silicon_ghoti is offline
AKA: I think I'm a freshman?
AKA: Luke
FRC #1425
silicon_ghoti will become famous soon enoughsilicon_ghoti will become famous soon enough
Originally Posted by Hachiban VIII View Post
Perhaps I should qualify my previous statement by saying that the ball was launched off of our ramp and landed 4' away. Such a design could be used to hoist the ball up the desired height and then shoot it over the overpass. But shooting from the ground... Well... With pneumatics I'm gonna say thats imposible
Hmmm... I was thinking the same until Monday afternoon. Now as I throw this out there I get the feeling that I may recieve some flak about not reading the manual, but I would like to ask, "Is this legal?"
What we did was take a 2" bore, 2' (about ish) stroke cylinder and cover up the air port nearest the piston, then we pressurized the other side to 60 psi. The piston extended out about 16" and stopped. We then removed the cover (thumb) from piston side port and the piston shot out with a resounding CLANG!!!! (In otherwords a GREAT deal of force.)
But the reason why our mentors questioned the legality is the little FIRST rule that states that, you cannot compress air in "non-Clippard" containers. I have asked an alum, and have yet to hear back. Now I'm curious as to what the FIRST community has to say.
What? You guys still opperate in only 2 dimensions?
This is a BEAR, it saves you.
Ghoti is pronounced "fish," ain't that sumthin'?
  #36   Spotlight this post!
Unread 09-01-2008, 02:29
Woody1458's Avatar
Woody1458 Woody1458 is offline
AKA: Woody Jansen
FRC #1458 (Danvillans)
Woody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to beholdWoody1458 is a splendid one to behold
Send a message via AIM to Woody1458
Originally Posted by Swampdude View Post
Well here's what I wanted to do but couldn't because the gigantic flag holder is in the way, although I'd love to see someone try it. Basically, if you could hold the ball at the end of a pole (about 4' long maybe) behind your bot, as you travel towards the bars (finish line), plant the front end of the pole in the carpet with a grippy foot on it, and you pole vault the ball using the bots inertia.
The bot itself is your best source of stored energy which can be transfered into the ball.
If you got this to work, you would probably win every design award your regional offers. lol
"Everything we produce is made of: Duct Tape, zip ties, and hope" - Christian Allinson 1458
Anyone can watch Westcoast Choppers and see adults build things, but FIRST is great because it encourages kids to do the building and adults to do the watching.
GO DANVILLANS!!
  #37   Spotlight this post!
Unread 09-01-2008, 05:44
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
an idea that was thought up by my team was to use a holder underneath the track ball, make the holder go up or down in angle, then have like a pneumatic bulldozer bar shoot out and almost kick it over or shoot if you prefer.
  #38   Spotlight this post!
Unread 09-01-2008, 06:51
Koko Ed's Avatar
Happy Birthday! Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
We're planning on using telekinesis.
  #39   Spotlight this post!
Unread 09-01-2008, 09:48
GaryVoshol's Avatar
Cogito ergo arbitro
Hmm, can you prove that's a legal power source? As long as you don't use gerbils, I suppose it passes the flowchart.
(since 2004)
  #40   Spotlight this post!
Unread 09-01-2008, 09:55
AHS1599's Avatar
AHS1599 AHS1599 is offline
Parent/Mentor
FRC #1599 (Techromancers)
Team Role: Parent
AHS1599 is an unknown quantity at this point
Trebuchet?
2007 NASA/VCU Regional Semi-finalist
  #41   Spotlight this post!
Unread 09-01-2008, 11:26
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
1885 is considering using the power of steam, so we're looking into building a great big pot with boiling water beneath a "cannon". It will be complete with a pressurization chamber and several parallel tubes since the durn things are so tiny. We'll also have some 2" Bose speakers on the right side of our robot pointing to the crowd that will play a nice BOOM whenever the ball is shot. Vintage late 1800's
No, I'm not serious
GitHub
  #42   Spotlight this post!
Unread 09-01-2008, 11:54
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Well you think with over 16 years in the business some form of mutation would show up. That or it's a particularly potent form of geekiness.
  #43   Spotlight this post!
Unread 09-01-2008, 11:57
chrisrobin
Posts: n/a
How about dribbling the ball from below. As you drive around you start bouncing the ball straight up in the air. You only have to add a small amound of energy with each bounce thus everything would be quite safe. With each bounce it gets higher and higher and as you pass under the overpass you stop the robot and the ball keeps going. Then you run under the ball and catch it for the next lap. I think a robot that can dribble would definitely earn your team some kind of technical award.
  #44   Spotlight this post!
Unread 09-01-2008, 13:48
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Sounds like you'd be a perfect alliance partner for us! We'll install our own speakers and play miketwalker yelling out "Oink, oink!" just before you fire!
I can smell the Einstein gold already...
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
  #45   Spotlight this post!
Unread 09-01-2008, 18:22
ar2 ar2 is offline
FRC #1778
ar2 is an unknown quantity at this point
our team is considering the forklift + electric actuator design.
We would forklift the ball atleast 3' above the ground and use the actuator to hurdel the ball over the overpass... of course balance is crucial in this case, but if we tilt fork lift so it would form a right triangle from the back of the robot of the front, all the weight will be on the center of the bot rather than the front...
what do you think??
Throwning the ball over the over Pass eastsideboma Rules/Strategy 16 15-01-2008 12:56
How do you get your other ball Jeff 801 Rules/Strategy 80 07-01-2008 17:59
pic: Dimensions of the Trackball on the Overpass Bethany Mc. Extra Discussion 2 07-01-2008 09:01
How to filter the points to get only the left most and right most? tommy_chai Programming 2 28-11-2007 11:39
Height of the bar over bonus ball structure punarhero General Forum 3 17-01-2004 14:39
