Go to Post every year, Dean's speeches get better. in the process, he's also teaching people to be patient. - Winged Wonder [more]
Unread 09-01-2008, 08:03
Re: AMPs for RC and Compressor
The RC is dynamic but the internals are voltage regulated and will shut down if the regulator is asked to supply more than 1.5 amps. However, the RC is the most critical component on the robot. Insure that power is connected to a point near the battery in you design and at a point where high current will not lower the voltage to the RC during match play. The RC will suspend operation when the voltage falls below 8 volts for a short period of time. During this time, the RC is powered by the backup but all outputs are inhibited.
The compressor start current is 25 amps while it's run current is between 10 and 12 amps. Due to the high start current for the this Spike only, electrical rules allow you to change the 20 amp fuse in the Spike to a 20 amp circuit breaker. Do it now so you won't forget. The fuse will burn open eventually.
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
compressor and light question... archiver 2001 5 24-06-2002 00:47
