Go to Post I've never liked the pressure pads. This just confirms my suspicions: Pressure pads hate robots. It must be some inferiority complex or something. - Andy A. [more]
Unread 08-01-2008, 21:25
robogeek753's Avatar
robogeek753 robogeek753 is offline
Droid Master
AKA: Bradley
FRC #0753 (The High Desert Droids)
robogeek753 is an unknown quantity at this point
Hurdling using the overpass
I realize that this question has been asked (sort of) on other threads and answered (again, sort of). However, given our specific strategy, I am curious as to if this technique would count.
So, our theory is that we get the ball to around 6 feet, the push it from below such that the TRACKBALL rolls up onto the OVERPASS. (we've tested it and it works). Now, if the ball rolls all the way across and falls off then we just let it bounce and continue on. However, if it settles into one of the depressions (far more likely) we just push it out (with the same device that pushed it on) and onto the next quad (completing the CROSSING) and then proceed to let it bounce and then we gain control again and so forth.
If either scenario (especially the second) happens, is it a hurdle? I would say yes, simply because it crosses the finsih line while being above the overpass (remember, crossing isn't complete until the whole thing goes over the line). What do you think?
Really, simpler is better; really, I swear
WHY DON'T YOU BELIEVE ME???
Unread 08-01-2008, 21:31
IbleedPink233's Avatar
IbleedPink233 IbleedPink233 is offline
FRC #0233 (The Pink Team)
IbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to beholdIbleedPink233 is a splendid one to behold
Re: Hurdling using the overpass
The only real restrictions on Hurdling are that the Trackball has to go over the Overpass and that it has to touch the ground or another bot afterwards, so your tactics look legit to me.
Unread 08-01-2008, 23:10
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
I believe that your analogy is correct.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 08-01-2008, 23:44
Droid Master
AKA: Bradley
Sorry, but by analogy being correct, do you think that it would count as a hurdle?
Unread 08-01-2008, 23:46
davidfv davidfv is offline
FRC #0399 (Eagle Robotics)
Team Role: Tactician
davidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant futuredavidfv has a brilliant future
Yes, our team is also looking at this being a legal hurdle... If I hear different I will post a new reply.
David
Davidfv
Mentor/Drive Coach
Unread 09-01-2008, 00:19
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
HURDLING: The act of completing a HURDLE. To be considered in the process of HURDLING, the ROBOT must:
be in its own HOME STRETCH, and
be in POSSESSION of a TRACKBALL, and
be moving toward the OVERPASS and/or elevating the TRACKBALL so that the top of the TRACKBALL is higher than the LANE DIVIDER.
All of these points seem valid with what you want to do. I don't see any problem with pushing it over. The only thing I can see that may pose as an issue is speed. But, its perfectly legal it looks like.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 09-01-2008, 00:20
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
THere is no mention of speed in the rule, so it sure sounds like a hurdle to me!
Unread 09-01-2008, 08:10
The Voice of WNY
I wasn't saying too fast or too slow. However, in general it would be slower than just placing it over the overpass.
Josh Goodman
Unread 09-01-2008, 08:24
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
How legal is this:
Get the ball over the overpass, without passing the finishline yourself, and then have an alliance member push the ball back to you. Then repeat.
There isn't any rule about the ball going backwards around the track (that I know of) .
(Edit) Sorry, forgot about rule <G13>, that ball has to pass the other alliances finish line.
Design. Build. Dew.
Unread 09-01-2008, 08:28
MrForbes's Avatar
AKA: Jim
You can do that, but it will only be scored as a hurdle if it passes over the opposing alliances finish line every time....
see rule <G13>
Unread 09-01-2008, 08:32
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Should be fine as long as the hurdling robot is not impeading and the alliance robot is able to make the trackball cross over the opposing alliances finish line before it returns it to the hurdler.
Note: the alliance robot could pass the trackball directly back to the hurdling robot so that the hurling robot could place the trackball on the overpass for the 12pt bonus at the end without having the trackball cross the opposing alliances finish line
Unread 09-01-2008, 08:35
diesel's Avatar
FRC #2077
You're right Squirrel, Sorry.
Design. Build. Dew.
Unread 09-01-2008, 08:39
Miniflash's Avatar
Miniflash Miniflash is offline
AKA: Gordon Wyant
FRC #2028 (Deep Impact)
Team Role: Human Player
Miniflash is on a distinguished road
id say that it would b a complete hurdle because it did go completly over the over pass
Unread 09-01-2008, 08:46
GaryVoshol's Avatar
Cogito ergo arbitro
The problem might be in the second point of the definition of HURDLING. While the ball is sitting on the overpass, the team has given up POSSESSION.
Variations on this scenario (all assume counterclockwise direction):
  1. Redabot 1 puts the ball on the overpass, and then immediately knocks it off.
  2. Redabot 1 puts the ball on the overpass, and then Redabot 2 knocks it off.
  3. Redabot 1 puts the ball on the overpass, circles the track, and then knocks it off the next lap
  4. Redabot puts the ball on the overpass, and then Blueabot knocks it off.
Which of these counts as a hurdle?
(since 2004)
Unread 09-01-2008, 14:21
Hard to tell. Hurdling is defined for a robot, but the definition of Hurdle--which is separate--is a little unclear. At this point, Scenario 3 wouldn't count (I think) because it would be a place and a knockdown. Scenario 1 might count, if the ball never settled. I'm not sure about the other 2 scenarios.
How to get the ball over the overpass!? ar2 General Forum 63 11-01-2008 23:58
hurdling daftpunk79 General Forum 5 08-01-2008 20:06
Track balls off the overpass in Hybrid mode- who scores? Japper Rules/Strategy 1 07-01-2008 11:24
pic: Dimensions of the Trackball on the Overpass Bethany Mc. Extra Discussion 2 07-01-2008 09:01
Hurdling akash155 Rules/Strategy 3 05-01-2008 23:50
