Go to Post FIRST rocks, thats for sure. - Dan Richardson [more]
Unread 09-01-2008, 10:54
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Small robots in 2008
How many teams have toyed around with the idea of making the smallest robot you can with the required components?
These can be advantagous as far as just running laps if you don't want to hurdle balls.
I'm predicting we will see some 1' x 1' robots who's mission is to just to race around the track doing laps and gaining those points as fast as they can.
Hopefully designers of these robots will at the very least take the time to protect themselves from a 10lb ball dropping on them from 7+ feet.
Unread 09-01-2008, 11:01
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: Small robots in 2008
We discussed it in our strategy meetings. We're not going to do it, but we definitely brought it up as an idea.
Any team planning on hurdling will probably want to have a robot with a large base (for stability), and herding on the floor might also require a larger base. If you're planning on just driving around, though, I could see a definite advantage to having a small frame, to make it easier to slip through small gaps.
Jeff Waegelin
Unread 09-01-2008, 11:07
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
So as long as there is enough room on the robot for such necessities like a battery and control system!
FRC78: 2010-Present
FRC121: 2002-2009
Unread 09-01-2008, 11:12
Hieb Hieb is offline
Hieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to beholdHieb is a splendid one to behold
I think a 1'x1' robot might be at a disadvantage due to the flag holder rule (can't recall which number right now). A 1'x1' robot that has a roughly 5' pole on it to support the flag would be a good candidate to flip as the much larger robots and balls are flying around.
Unread 09-01-2008, 11:21
JoeXIII'007's Avatar
JoeXIII'007 JoeXIII'007 is offline
Pragmatic Strategy, I try...
AKA: Joeseph Smith
FRC #0066
JoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond reputeJoeXIII'007 has a reputation beyond repute
Send a message via AIM to JoeXIII'007
I had fun with the idea in my head. The team agrees some team is going to make a dedicated lap running robot, and personally, if there is a team gutsy enough to do it, I would LOVE to see it happen.
Joeseph P. Smith
jpthesmithe.com
University of Michigan - Informatics (B. Sci. 2012)
General Purpose Programmer - Cooperative Institute for Limnology and Ecosystems Research (CILER) at NOAA-GLERL
Unread 09-01-2008, 12:06
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
For fun I designed a 10"x16" bot with all necessary legal components out of kop stuff. I think we will build it just for kicks.
That big battery is a great counter weight. Even with a flag pole made out of steel I don’t think it would be a problem
Unread 09-01-2008, 12:13
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
We have tinkered with the idea of using a similar design to our "mini-me" robot from last year. If you were at the CO regional we were the little bot that looked similar to your kitchen sink. Very fast and maneuverable
Unread 09-01-2008, 13:57
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
The required bumper rule kinda puts a twist on the concept too. A 1'x1' chassis almost becomes a 2'x2' because of the required bumpers.
Ed Sparks
MECH TECH FRC-3959
Unread 09-01-2008, 15:41
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
The flag pole would be a bigger worry in that it would provide a great lever for a trackball or other robot to tip your robot over with.
Unread 09-01-2008, 15:44
daftpunk79's Avatar
daftpunk79 daftpunk79 is offline
AKA: Lizzy
no team (Bomb Squad)
daftpunk79 is on a distinguished road
Send a message via MSN to daftpunk79 Send a message via Yahoo to daftpunk79
ok, im weird i gues, i think it would be kinda cute to see a little robot zipping around the track as fast as possible.
Unread 09-01-2008, 15:23
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
One lap only gets you 2 points. So, other than a rookie team, this seems like a fruitless strategy.
1 lap =
2pts in Teleoperated mode.
But...
in just 1 lap of Hybrid mode, a small, very manuverable, quick robot can go wayyyy past 2 points a lap. Just how many?
We'll see... depending on how the rules are clarified in the next few weeks will determine that.
7.3.3.1 ROBOT scoring
<G03>
All ROBOT scores are awarded to the ALLIANCE associated with the scoring ROBOT.
<G04>
During the HYBRID PERIOD, a ROBOT will earn 4 points each time it CROSSES either
FINISH LINE.
<G05> During the HYBRID PERIOD, a ROBOT will earn 4 points each time it CROSSES either
LANE MARKER.
<G06>
During the TELEOPERATED PERIOD, a ROBOT will earn 2 points each time it CROSSES its FINISH LINE.
<G07>
A ROBOT that has CROSSED its own FINISH LINE must CROSS the opponent’s FINISH
LINE before it can score by CROSSING its own FINISH LINE again.
Unread 09-01-2008, 15:52
Best Available Data
FRC #1778 (Chill Out!)
I'm willing to bet anyone who takes this strategy will end up in the middle of the pack. Why? Becuase they can outscore the teams who bite off more than they can chew (and by and large these "bite off more than they can chew teams" are veterans). I envision a lot of hurdling robots who won't be able to grab a ball well, and won't be able to guarantee a hurdle with any degree of certainty. While they will probably end up racing around the track for points, they won't be as well suited as these mini bots.
Additionally, this year assuming you get 2 hurdlers, or even a good hurdler and a good herder, I seriously the doubt the alliance selection field would be deep enough at any event save the championship to field another good ball handling robot on your alliance. Thus, a super fast controllable mini racer is looking like a pretty darn good choice for that 3rd robot.
Unread 09-01-2008, 16:30
ham90mack's Avatar
ham90mack ham90mack is offline
President of RIT FIRST
FRC #0073 (The Illumination)
ham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really nice
Isn't there a rule saying that the longest dimension of the robot needs to be vertical when starting the game? Let me see...
<G18> ROBOT Orientation - ROBOTS must start the MATCH with their long (maximum) dimension in a vertical orientation. After the start of the MATCH, ROBOTS may change their orientation such that the long dimension is either vertical or horizontal. Refer to Rule <R08> and Rule <R17> to determine how this affects the use of STANDARD BUMPERS and FLAGS.
So I guess that means you can't have a small, flat robot this year... Unless the flags add to that maximum dimension.
Old stuff:
FRC 2007 Strategy Solver. Version: 2.55. Progress: done.
Unread 09-01-2008, 19:12
ADZDEBLICK's Avatar
ADZDEBLICK ADZDEBLICK is offline
AKA: Andrew Zdeblick
FRC #0195 (Cyber Knights)
ADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to beholdADZDEBLICK is a splendid one to behold
Send a message via AIM to ADZDEBLICK
the rule states that hour longest (maximum) dimension must be vertical. I interpreted this to mean that your foot print at the start of the match can not be greater than 28x38, but there is no limit to how small it can be as long as you don't start the robot to have the 5' dimension horizontal.
2008 Offseason event MARC being moved to JUNE 28, 2008 Steve Ketron Off-Season Events 10 21-03-2008 07:55
[Official 2008 Game Design] OK, so YOU design the 2008 game... dlavery FRC Game Design 25 20-02-2008 23:31
Are FIRST robots actually robots? EHaskins General Forum 39 14-12-2006 21:40
Robots and Small Balls archiver 2001 6 24-06-2002 00:44
Small Parts archiver 2000 2 23-06-2002 23:09
