Re: Holonomic vs Mecanum Help!!
The short version is, both are reasonably complex to program mechanum will result in a more highly geared robot for similar speed, and I'm really not sure which ends up with the best traction. |
apologies I was mixing up my terms, I had meant to make it more of a Meca vs Vertical Plastic Omni design.... There is no main question but rather i have several questions that all have to do with the stability and "pushing power" between the two designs
I would simply try to avoid pushing matches with either system. That's the point of the speed, and neither system pushes particularly well compared to a straight four wheel drive, crab, 6 wheel drive, or tread. Basically 3/4's of the bots will out-push you.
both systems are the same except that mecanum can goes faster forward and backward than omni (assuming everything else is the same). Mecanum can also make the chassis simpler, depending on the materials/methods you use.
The same exact code can be used with either configuration.
Generally, 341 has used conventional omniwheels for holonomic drives, since the available wheels are of much higher quality (in my opinion) than off the shelf mecanum wheels. If you can make your own high-quality mecanum wheels, you can get away with a more normal looking frame. |
I think it would be a little simpler to program mechanum reliably as apposed to omni, as with mechanum, you can have a regular tank drive operator interface with one of the controllers also controlling side-to-side motion on the x-axis of the joystick. This is fairly simple code, the hardest part is just telling the processor how to move the front wheels back and forth opposite the back wheels, but that's pretty easy. With omni holonomic/Kiwi/Killough the robot pretty much has to be programmed to know what's forward. From what I've seen in VEX, Mindstorms, and FRC, mechanum tends to lend itself to a slightly more powerful drive train, as omni holonomic has almost no resistance to movement, basically making it a hockey puck on wheels (note the incessant fishtailing of 2158's robot from 2007 FRC, where we only had 2 omniwheels, and were pushed around easily).
#7
Note: When I refer to omni, I mean a robot which has 90 degree omniwheels, one on each side of a square (or rectangle). That square can be rotated from the robot frame, meaning you have a wheel diagonally in each corner.
you should go with the 1565 Linkage drive system
![]() (that's IMHO of course ) thats the best bet lol! (look it up!!) |
| Mecanum Drive - Help | Smoking_Gun | Programming | 22 | 04-12-2007 20:51 |
| Holonomic/Omni vs Defense | Alex Burman | Technical Discussion | 15 | 15-02-2006 20:35 |
| Holonomic Drive Question | Jeff Waegelin | Technical Discussion | 12 | 20-11-2005 21:23 |
| Holonomic... | Greg Perkins | Technical Discussion | 2 | 02-02-2005 11:59 |
| holonomic drives | Max Lobovsky | Technical Discussion | 5 | 10-03-2004 21:31 |
