Go to Post Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs. - sanddrag [more]
Unread 09-01-2008, 08:36
Maggie27's Avatar
Maggie27 Maggie27 is offline
Maggie
AKA: Maggie
FRC #1708 (Natural Selection)
Maggie27 has a spectacular aura aboutMaggie27 has a spectacular aura aboutMaggie27 has a spectacular aura about
Send a message via AIM to Maggie27
Your thoughts on Mecanum wheels....
What are your thoughts/tips on mecanum wheels?
I believe my team has already decided to use these this year, but if you have any good reasons as to why not, or even as to why we should use them, please post.
I've seen other threads on mecanum wheels, and they've helped a little, but all I really got out of them was that we lose about 45% "push". Is that all?
http://andymark.biz/am-0083.html
http://www.araa.asn.au/acra/acra2002...eter-Tlale.pdf
Unread 09-01-2008, 08:59
Back after 4 years off
FRC #5279
Re: Your thoughts on Mecanum wheels....
Mecanum wheels are pretty cool, just a couple of things to keep in mind are some sort of suspension to ensure all wheels are always in contact with the floor. Also I would reccommend using the gyro to make sure the robot tracks straight, otherwise if the mechanical compenents of the robot are not perfect then it will drift.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 09-01-2008, 09:34
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
more moving parts. more things that can break
Unread 09-01-2008, 09:44
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
also, your programmers will need a lot of time to develop and test (also trig skills)
1675 used mecanum fro the first time last year, and although it was hard, I had fun learning all the vector theory to program it.
Unread 09-01-2008, 10:06
Maggie27's Avatar
Maggie
AKA: Maggie
That's what I'm most worried about. My team has a tendency of having things break when we MOST need it!
Also with the programming, we have almost no knowledge on, so I'm definately worried about this as well. We do have some people learning it though as we speak.
Unread 09-01-2008, 10:07
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
amen to that, thats the biggest flaw in mecanums, they drift... sometimes alot!!
Unread 09-01-2008, 10:13
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
We used the AndyMark mecanum wheels last year.... with some problems.
The first set of wheels that we received, the tabs on each side of all the wheels weren't bent to the proper angle (or even evenly!)
We received new plates from AndyMark, that were bent properly (we still needed to do some minor adjustments, but it was much better.) The biggest problem after that was how freely the rollers spun. Some rollers on the same wheel would spin freely, while others were completely bound up.
This was just our experience though, because I know that The Enforcers (Farmington, CT) used mecanum wheels last year, with very very minimal problems (as I recall, they opened the box and assembled the wheels with no modifications.) They also somehow got away with going through all of their regionals using the original carrier plates in the BaneBots transmissions.... (lucky!)
So all in all, the mecanum can provide some good features that can't be seen in other drive trains, but the assembly is very heavy (4 motors and 4 gear boxes), and can require A LOT of fiddling with.
From the coding aspect (my specialty), it didn't take long to come up with code to drive the system. We actually have the BaneBots encoders installed on all four wheels from last years bot, which we implemented into a PID loop...... but the BaneBots encoders are constructed poorly, and after a few matches, the superglue (Yes, Superglue) thats holding the encoder wheel to the shaft starts to heat, and allows the wheel to move around, and eventually grind up against the encoder, rendering them useless. I would not recommend the BaneBots encoders.
Jacob
Unread 09-01-2008, 10:17
kSniper's Avatar
kSniper kSniper is offline
Never say Die
FRC #0303 (Panther Robotics)
Team Role: Animator
kSniper is an unknown quantity at this point
Send a message via AIM to kSniper
Yea my team is debating between several drive trains as well, but we are stuck on the comparisons between holonomic and mecanum....i have made another thread for this so if anyone could help me out i have a few questions posted on it.....thanks
Never say die
Overdrive....to hurdle or not to hurdle that is the questions
Unread 09-01-2008, 11:00
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Mecanum wheels take immense amounts of tweaking of the rollers, just a half turn of the bolt too much can make it not spin freely. There also needs to be some kind of suspension, spring steel makes a really good suspension for mecanums.
From the construction stand point. If you haven't built a mecanum in the fall, it may be a little too labor/software/testing intensive to be successfully done in the build season.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 09-01-2008, 12:02
DB_UPS's Avatar
Happy Birthday! DB_UPS DB_UPS is offline
tool or die that is the question?
AKA: Ryan Quinlan
FRC #1675 (The Ultimate Prtoection Squad)
DB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura about
Send a message via AIM to DB_UPS
Like josh said, Our progrem team did have fun programing it. Its wasn't really hard to build, we had a rolling chassic by week two last year (it wouldn't been soon by due to the shortage of AM mecanum we get done a little later) it was on the KOP chassic with the wonderful BaneBots transmissions.
The only problem we truely had was it wasn't encoded. It was open loop.
Would i do it again, sure if we make a custom chassic so the wheel are perfectly squared and encoded, i would do it in a heart beat.
Unread 09-01-2008, 13:57
yoshibrock's Avatar
yoshibrock yoshibrock is offline
Mechanical Magician
AKA: Brock
FRC #0540 (Talon)
yoshibrock will become famous soon enoughyoshibrock will become famous soon enough
Send a message via AIM to yoshibrock
Some cons to Mecanum wheels are fragility (they break rather often) and drift (which can also be a pro). With any wheels that are omnidirectional you get pushed around a lot easier (which isn't too much of a problem this year, but still something to consider). Also, if you don't use a suspension, they're very bumpy. Some pros are mobility and a unique experience for your drivers.
There is no charge for awesomeness.
Am I a hero? I really can't say, but yes.
Unread 09-01-2008, 16:16
Jared Russell's Avatar
Taking a year (mostly) off
One unavoidable problem with both Mecanum and Kiwi-style omni drives are that you are essentially throwing away 30% of your speed. For every rotation of the Mecanum wheel, the robot only translates 1/sqrt(2) = 70.7% of the wheel's circumference when driving straight. Driving diagonally (with two wheels driving and the other two fixed) alleviates this problem.
This is why 341 changed our 2007 kiwi drive from this:
to this:
last year.
Unread 10-01-2008, 00:41
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
what would be a good encoder choice? banebots is our first choice because we are considering using the banebots 56mm tannie... (worked great last year... already have all the parts). we'll probably be using the kitbot chassis, so as to aliviate as much cost from the drivetrain as possible.
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Unread 10-01-2008, 01:09
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
to this:
last year.
This is not a- much of a problem with mecanum, because the rollers don't spin when driving forward or backward you only lose speed going sideways/diagonally.
Unread 10-01-2008, 01:12
Zyik Zyik is offline
Observer
Zyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond reputeZyik has a reputation beyond repute
From what I've seen the benefits of having Mechanum wheels are:
  • Allows for good freedom of movement
  • Amazingly agile
  • They look cool
I don't know how they are for speed or if having them effects that at all. However I have seen my teams robot push mechanum wheeled robots almost anywhere. There doesn't seem to be anything you can do once we come up behind you, if we wanted you to go away from the rack then thats exactly where you were going.
Mecanum wheels akash155 General Forum 12 20-02-2007 22:15
Mecanum Wheels Calvin_1631 Motors 7 09-02-2007 13:29
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
