Go to Post If you are adult enough to be a participant in this program, then you are adult enough to act like an adult. - Beth Sweet [more]
Unread 09-01-2008, 12:03
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: pic: Omni Design Trial
Originally Posted by Fred Sayre View Post
Wait, so when you are rolling forward and there is a sideways force, where is that force coming from? It is the motors. You don't get the applied force for free.
Some of the motors force is used by the wheel trying to move sideways, but the rollers aren't actually turning, so all of the wheel's velocity is transferred to the ground.
The difference between mecanum and omni-wheel based holonomic is that on an omni system the wheels actually do move sideways when driving forward, while on a mecanum setup they don't.
Unread 09-01-2008, 12:11
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The difference you're observing may simply be a function of how much you've tightened the screws on the AndyMark mecanum wheels. We have had a functioning mecanum drive train for more than a year and I swear on my mother that the rollers turn while we're driving forward or backward or sideways or upways or downways or anyways at all.
You cannot transfer velocity to the ground. You can impart a force on the ground and the reaction to that force will make your robot move, but the Earth is a bit heavier than your robot and you're probably not having a significant effect at making it go faster or slower.
If the rollers are not turning, as you suggest, then the wheel is not trying to move sideways. If the wheel is not trying to move sideways (as it cannot possibly discern your intention or what the rest of the wheels are doing) it will not, under any circumstances, strafe. A roller that's not turning cannot magically impart a force sideways.
--Madison--
...down at the Ozdust!
Unread 09-01-2008, 12:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
And if you are moving straight ahead, the rollers can't roll. Even if they're loose.
It works both ways.
I'll paint half of each of the rollers and make a movie....
Unread 09-01-2008, 12:16
Madison's Avatar
FRC #0488 (Xbot)
It works both ways.
What's the difference between a wheel rolling forward for the sake of going forward and a wheel rolling forward for the sake of strafing and how did you get your rollers to know the difference?
--Madison--
Unread 09-01-2008, 12:23
MrForbes's Avatar
AKA: Jim
The only difference is that the rollers are rolling relative to the body of the wheel under the strafing condition, so there is "lost motion". In the straight ahead condition there is none, the drive system is quite efficient.
A wheel turning forward is going along the straightaway of the race track...a wheel strafing is going around a curve...usually we try to go as fast as we can on the straightaway, and we have to slow down for the curves. So, a mecanum drive is naturally suited to this game, while an omni drive is not, because it is wasting a lot of motor movement spinning the rollers on the wheels.
The rollers don't care at all. But you might care if you're trying to decide which drivetrain to use, and you are still considering both omni and mecanum holonomic drives.
Unread 09-01-2008, 12:31
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
The difference is in whether or not they're constrained and allowed to move forward by the motion of the bot. In a mecanum if it is moving forward the rollers won't turn because if they were the wheel would have a lateral velocity (different from force, there is a lateral force). On an omni when moving in the forward direction there is a lateral velocity so the rollers do turn.
However this means that in an ideal situation, when you have no friction in the bearings you will not see ANY difference between the two. You may see a slight difference in top speed because of the angle on the wheels but you will see absolutly no difference in power since no power is used up in heating the bearings.
In the real world you will see that in the forward direction since the mecanum rollers aren't turning there will be a slightly better efficiency and more power will get to the floor, but I would be willing to bet that you couldn't measure the difference cause when your talking about a 321 watt motor, the amount lost to the bearings is inconsiquecial.
Unread 09-01-2008, 12:34
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Though incredibly versatile, the standard Mecanum wheel has an unfortunate side effect which reduces its effeciency considerably. Its wide range of mobility is due to the fact that the peripheral rollers translate a portion of the motor force into a force perpendicular or at an angle to that produced by the motor. This means that are large portion of the force in one direction is lost through the translation into a resulting force by the rollers.
Losses of effeciency when traveling in a straight line are due to energy lost in a direction normal to that of travel through the peripheral rollers which bleed off available energy as they rotate.
From http://www.araa.asn.au/acra/acra2002...eter-Tlale.pdf
Unread 09-01-2008, 12:43
MrForbes's Avatar
AKA: Jim
Thanks for the explanation, Alex.
Unread 09-01-2008, 13:27
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Thank you, Fred. I don't know why I didn't think of quoting that paper earlier.
For anyone who's really interested in finding out all the science behind how a mecanum works, that paper is an excellent read.
I remember when I first came across that paper. I went to all of my friends saying, "See!? This is what I've been talking about!"
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 09-01-2008, 13:40
MrForbes's Avatar
AKA: Jim
Thanks for the explanation, Fred. We now know that the maximum force that can be transmitted by a mecanum wheel in the forward direction is not as high as with a regular wheel. How does this affect the power transmission? Is there more frictional loss because of the side pointing vector? If so, how could I calculate that?
Also, what about the speed? If the rollers are not rotating relative to the wheel body as in straight ahead driving, is the full speed of the motor applied by the wheels?
The paper is interesting, but doesn't offer any explanation...it seems to be mostly selling the new design.....it would be nice if it had even a little bit of actual theory, and really nice if it had some empirical data to back up the claims.
Unread 09-01-2008, 13:59
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
The friction comes into play of course, but that is a very hard number to get at short of actual experiments, and of course varies greatly with the type of mecanums being used.
Speed however will change. It is our experience that the rollers do in fact spin while going straight. On the ground the force is encouraging them to spin, and "perfect" traction would prevent that, but this is usually not the case. I suspect that there is some movement on the carpet, but additionally as soon as the wheel rotates the rollers will spin more as they pick up off the floor.
If at all possible, it would be a great test to get the same diameter wheels as the mecanum and compare speeds on the official carpet. We did not go into that much detail with our prototype analysis, but we made a rough estimate with vector calculations to adjust the gear ratios accordingly for our ideal fps.
Unread 09-01-2008, 14:07
MrForbes's Avatar
AKA: Jim
So, if you were to set up the wheels to be optimized for straight driving by adjusting the friction to be high enough that the rollers would not be able to roll at normal driving loads, would that make the sideways force vector on the rollers negligible under these conditions? I'm thinking that the inability to overcome static friction would keep the rollers acting like regular tread, and the wheels would indeed act almost like regular wheels under those conditions.
I'm thinking about this as it applies to this game only.
Unread 09-01-2008, 15:00
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
Right, at the cost of even less efficiency going sideways. You could also adjust the roller angle to be closer to an omni wheel to increase the straight driving performance and decrease the side to side performance.
In that paper they talk about adding the feature of being able to lock or vary the angle of the rollers on a mecanum wheel to increase performance. That would be an awesome, award worthy accomplishment by a FIRST team that I hope someone will at least attempt in this or future seasons.
Unread 09-01-2008, 15:09
MrForbes's Avatar
AKA: Jim
Or you could angle omni wheels at, say, 30 degrees to the long axis of the robot instead of 45 to achieve the same effect, right?
Unread 10-01-2008, 01:18
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
I'm kinda new with plastics, but why would you use UHMW for a chassis?
It would be virtually unbreakable, but isn't it flexible? And I though UHMW was used for more high friction situations(like chain tensioners)?
pic: vex omni drive 1902_Battery_SGT FIRST Tech Challenge 6 28-05-2006 17:55
Omni-Wheel Design fightoplankton Technical Discussion 7 08-01-2006 23:49
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
pic: Omni Idea Sachiel7 Extra Discussion 4 31-01-2005 12:46
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
