Go to Post Oh, and a general guiding principle: Don't be stupid. - Billfred [more]
Unread 09-01-2008, 12:19
ubergeek5075's Avatar
ubergeek5075 ubergeek5075 is offline
FRC #0910 (Foley Freeze)
ubergeek5075 is an unknown quantity at this point
Re: PROGRAMMING PROBLEM HELP!
Whenever we have a syntax error in our code, and our code on the line and after the line is grammatically correct, our next step is to make sure we aren't defining something previously defined.
Then we look at the code above it for syntax errors. For instance, if you have a line of code before that like this:
int new_variable
and forget the semicolon, then it will cause the error on the next line following. Same goes for braces and brackets, etc.
The only other thing i can think of is that the typedef is inside a function, which causes problems.
Easy C programming Problem fredliu168 FIRST Tech Challenge 6 19-11-2006 22:44
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
C programming problem... wasabi824 Programming 5 08-02-2004 01:04
multi-bank programming problem GregC Programming 3 14-02-2003 16:13
programming problem gthakore Programming 16 20-04-2002 12:21
