Go to Post it takes a village to raise a robot. - Taylor [more]
  #31   Spotlight this post!
Unread 09-01-2008, 12:25
AdamHeard's Avatar
Lead Mentor
Re: pic: Omni Design Trial
Originally Posted by squirrel View Post
No, it's not the end of the story....because I have a mecanum wheel sitting here, and you don't
Don't make assumptions about other teams without out making at least an attempt at fact checking. If you had even looked at 488 in the gallery, you'd see they had a fully functional (as M Krass already said) Mecanum drive well over a year ago. On top of that, M Krass has proven over the years to be a very knowledgeable member of CD; I have never seen her post any opinions as fact, she all ways has something to back up her statements.
Now, for the thread.... I would stay away from any sort of holomonic drivetrain this year. The manueverability will be nice, but all of the pushing and jostling that will happen in a match will make you wish you never did it....
  #32   Spotlight this post!
Unread 09-01-2008, 12:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Yes, I now know that she has mecanum experience....but it seems that she overlooked a highly relevant fact about the wheels. I did not think that she would have done this if she had a mecanum wheel at hand to play with.
I think we are all starting to agree on the subject now....
  #33   Spotlight this post!
Unread 09-01-2008, 12:30
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Yes, I now know that she has mecanum experience....but it seems that she overlooked a highly relevant fact about the wheels. I did not think that she would have done this if she had a mecanum wheel sitting at hand to play with.
Under no circumstances do I agree. Your understanding of the system, wheel in hand or otherwise, is fundamentally flawed.
I design things for a living -- mecanum wheels included -- and am quite familiar with their operation.
--Madison--
...down at the Ozdust!
  #34   Spotlight this post!
Unread 09-01-2008, 12:31
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
The difference is in whether or not they're constrained and allowed to move forward by the motion of the bot. In a mecanum if it is moving forward the rollers won't turn because if they were the wheel would have a lateral velocity (different from force, there is a lateral force). On an omni when moving in the forward direction there is a lateral velocity so the rollers do turn.
However this means that in an ideal situation, when you have no friction in the bearings you will not see ANY difference between the two. You may see a slight difference in top speed because of the angle on the wheels but you will see absolutly no difference in power since no power is used up in heating the bearings.
In the real world you will see that in the forward direction since the mecanum rollers aren't turning there will be a slightly better efficiency and more power will get to the floor, but I would be willing to bet that you couldn't measure the difference cause when your talking about a 321 watt motor, the amount lost to the bearings is inconsiquecial.
  #35   Spotlight this post!
Unread 09-01-2008, 12:34
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Though incredibly versatile, the standard Mecanum wheel has an unfortunate side effect which reduces its effeciency considerably. Its wide range of mobility is due to the fact that the peripheral rollers translate a portion of the motor force into a force perpendicular or at an angle to that produced by the motor. This means that are large portion of the force in one direction is lost through the translation into a resulting force by the rollers.
Losses of effeciency when traveling in a straight line are due to energy lost in a direction normal to that of travel through the peripheral rollers which bleed off available energy as they rotate.
From http://www.araa.asn.au/acra/acra2002...eter-Tlale.pdf
  #36   Spotlight this post!
Unread 09-01-2008, 12:43
MrForbes's Avatar
AKA: Jim
Thanks for the explanation, Alex.
  #37   Spotlight this post!
Unread 09-01-2008, 12:46
MrForbes's Avatar
AKA: Jim
In what way?
I'd like to know...really....
  #38   Spotlight this post!
Unread 09-01-2008, 12:56
Rupnick's Avatar
Rupnick Rupnick is offline
FRC #1675 (UPS - Ultimate Protection Squad)
Rupnick is on a distinguished road
Send a message via AIM to Rupnick
Mecanum wheels are not that hard to find or that expecive. andymark makes an 8inch and 6inch wheel. last year my team used the andymarks and might be doing it again this yea its a possiblility.
  #39   Spotlight this post!
Unread 09-01-2008, 13:01
Fidgetting
For a small team the $300 for a complete set of mecanums can be a real hardship where as you can get a complete set of omins for $80 that are more than good enough... I don't know how these omnis compare to the andymark but I do know that they work very well and are more that durable enough for the game.
  #40   Spotlight this post!
Unread 09-01-2008, 13:12
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
In what way?
Thinking that mecanums perform the same as a solid wheel when traveling forwards and backwards is flawed. Motors can not be applying a force and simultaneously perform as if they were not applying that force.
If you draw a vector diagram for a mecanum wheel, you get a line going at an angle to the axis of rotation. The forward pointing vector is a component vector and is of less magnitude than the diagonal vector. Summing these forward vectors give you a lower magnitude then if you had standard wheels in which the entire vector is pointing in the forward direction.
  #41   Spotlight this post!
Unread 09-01-2008, 13:27
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
Originally Posted by Fred Sayre View Post
Thank you, Fred. I don't know why I didn't think of quoting that paper earlier.
For anyone who's really interested in finding out all the science behind how a mecanum works, that paper is an excellent read.
I remember when I first came across that paper. I went to all of my friends saying, "See!? This is what I've been talking about!"
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
  #42   Spotlight this post!
Unread 09-01-2008, 13:40
MrForbes's Avatar
AKA: Jim
Thanks for the explanation, Fred. We now know that the maximum force that can be transmitted by a mecanum wheel in the forward direction is not as high as with a regular wheel. How does this affect the power transmission? Is there more frictional loss because of the side pointing vector? If so, how could I calculate that?
Also, what about the speed? If the rollers are not rotating relative to the wheel body as in straight ahead driving, is the full speed of the motor applied by the wheels?
The paper is interesting, but doesn't offer any explanation...it seems to be mostly selling the new design.....it would be nice if it had even a little bit of actual theory, and really nice if it had some empirical data to back up the claims.
  #43   Spotlight this post!
Unread 09-01-2008, 13:59
Fred Sayre's Avatar
AKA: Fred Sayre
FRC #0488 (xbot)
The friction comes into play of course, but that is a very hard number to get at short of actual experiments, and of course varies greatly with the type of mecanums being used.
Speed however will change. It is our experience that the rollers do in fact spin while going straight. On the ground the force is encouraging them to spin, and "perfect" traction would prevent that, but this is usually not the case. I suspect that there is some movement on the carpet, but additionally as soon as the wheel rotates the rollers will spin more as they pick up off the floor.
If at all possible, it would be a great test to get the same diameter wheels as the mecanum and compare speeds on the official carpet. We did not go into that much detail with our prototype analysis, but we made a rough estimate with vector calculations to adjust the gear ratios accordingly for our ideal fps.
  #44   Spotlight this post!
Unread 09-01-2008, 14:07
MrForbes's Avatar
AKA: Jim
So, if you were to set up the wheels to be optimized for straight driving by adjusting the friction to be high enough that the rollers would not be able to roll at normal driving loads, would that make the sideways force vector on the rollers negligible under these conditions? I'm thinking that the inability to overcome static friction would keep the rollers acting like regular tread, and the wheels would indeed act almost like regular wheels under those conditions.
I'm thinking about this as it applies to this game only.
  #45   Spotlight this post!
Unread 09-01-2008, 14:47
Bob Steele's Avatar
AKA: Bob Steele
I just wanted to point out a small error in the discussion regarding Force and Motion.
NET force will result in Acceleration ... constant velocity requires no force whatsoever.
When we accelerate robots we see the result of all the forces involved. The net force.
The other forces on the robot are varied and the one we should discuss here primarily is friction (which is a result of the weight of the robot and the coefficnet of friction between the wheels and the carpet). This frictional force is what accelerates the robot. This frictional force is a result of the wheels applying a force to the carpet and carpet pushing back.
The net force on the robot, when it is going forward is in that direction.
If the angled wheels on a set of mecanums are not turning it is simply indicating that the sideways forces are balanced. It does NOT indicate there are NO sideways forces. I would imagine that the pin loading on the bearings in this angled state is much different than when it is moving parallel to the wheel's orientation.
I you could measure the temperature of these wheels over the course of the match I would be very surprised if they do not get quite warm.
This loss of efficiency that we all discuss with holonomic or mecanum systems has to result in energy being spent somewhere else...
Anyway these are my suggestions on this topic. Specifically they would indicate why that holonomic drives and mecanum drives have to work in the same way. Force applied does not net acceleration. Net force does.
Good luck to everyone no matter what drive system they use!!!
Have a great season!!!
May the NET FORCE be with you!!!
pic: vex omni drive 1902_Battery_SGT FIRST Tech Challenge 6 28-05-2006 17:55
Omni-Wheel Design fightoplankton Technical Discussion 7 08-01-2006 23:49
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
pic: Omni Idea Sachiel7 Extra Discussion 4 31-01-2005 12:46
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
