Vacuum
I know its legal to charge the pneumatic system prior to the match, but is it legal to create a vacuum or suction and store it in a tank prior to a match?
(We would plan on using the venturi generator from last years KoP) |
Re: Vacuum
I think it would be very hard to do that. Also, is the venturi even legal this year?
Re: Vacuum
Thats what I was wondering...
Re: Vacuum
Yes, the venturi generators from last year are legal as per Rule <R87>. However, they don't work in such a way that you could "pre-charge" a tank, when you open a solenoid valve letting air through them they create the vacuum, rather than having a "vacuum tank". In addition, those things are serious on the air usage, so if your going to use them for extended periods of time, you need the compressor on-board.
--NOTE-- We used them last year to pick up the tubes, worked pretty well, but the skin of that ball is going to be much harder to use vacuum cups on. |
Re: Vacuum
Still allowed... <R87>
For the purposes of the FIRST competition, a device that creates a vacuum is not considered to be a pneumatic device and is allowed. This includes, but is not limited to, venturi-type vacuum generators and off-the-shelf vacuum devices (as long as they are powered by provided or permitted motors). |
Re: Vacuum
I'd like to see one with only one point of contact on a Trackball that actually would work. I don't think it will.
The reason I say this, is because the fabric outer covering of the Trackballs will not result in a very good seal as the nice one layer vinyl tube would last year. If you tried this, you would probably need 2 or more on quite opposite sides of a ball, and in that case, why even bother adding the venturi mechanism when you basically have a gripper with 2 points of contact anyways? |
#7
Re: Vacuum
Re: Vacuum
Vacuum can be used for many things besides picking things up.
If you can figure out a way to store vacuum in a sealed tank (think solenoid valves) and prevent the vacuum from 'leaking' out through the venturi (think timing of air supply), then yes, you should be able to store vacuum prior to a match, by "charging" the tank in the pits, sealing it up. Of course, this is merely my opinion, I cant say if it is legal or not, but this has been done by teams last year. Don |
#9
Re: Vacuum
thanks, thats what I thought, just trying to convince a mentor that it won't work...
#10
Re: Vacuum
A vacuum is not a pnuematic system. The solenoid rule clearly states that you can only use solenoid valves for pnuematics. Vacuum is not equal to pnuematics therefore solenoid valves used to contain the vacuum are not allowed. |
#11
Re: Vacuum
Is a shop vac legal as a vacuum source?
#12
Re: Vacuum
A Shop Vac contains a motor that is not FRC legal. If you can power it with an FRC legal motor the other parts of the Shop Vac are certainly allowed.
#13
Re: Vacuum
One thing to keep in mind with vacuum is that the forces you can create are rather limited unless you have little leakage or very high vacuum generating capacity. Recall that a perfect vacuum is by definition -1 atm relative to ambient pressure, which is approximately 14.7 psi, so to exert a lot of force, you need a lot of area, which in the real world usually means you have a lot of leaks. Assuming your vacuum storage tank and evacuation system are legal (I haven't looked into that aspect), you would probably need a pretty large tank if you plan to grip a leak-prone surface like the Trackball.
#14
Re: Vacuum
No comment on the legality of it ... but technically it'd be a challenge to convince me that it's worth the effort. We tossed that idea around for a little while during our brainstorming sessions, but it died off somewhat quickly.
For ball handling, with it's somewhat porous cover, the volume of air that you'd have to move would be huuuuge ... and the area of the suction cup would have to be pretty large. I don't think that a tank behind a solenoid would do the trick. I'd wager that you'd have to be constantly sucking large volumes of air to maintain a partial vacuum at the cup If it's not for ball handling, then it's hard to comment on it's feasability. I suppose that there could be some use for a (partial) vacuum, but aside from ball handling, nothing comes to mind at the moment. ... other than an idea for next year's competition ... can anybody say Roomba-bots? Next year's trackballs could be dime-sized, and we'd have to gather as many as possible. The regional winners get to travel to Mr. Kamen's house to help with his spring cleaning! ![]() |
#15
Re: Vacuum
| Vacuum Valve | Andrew Blair | Pneumatics | 14 | 12-03-2007 19:49 |
| Vacuum tube. | Eric Scheuing | Kit & Additional Hardware | 11 | 13-01-2007 14:04 |
| Vacuum Generator | Peter Matteson | Technical Discussion | 0 | 04-02-2005 15:58 |
| Vacuum | NoRemorse | Rules/Strategy | 25 | 22-01-2004 12:34 |
| Vacuum | nwagers | Pneumatics | 16 | 31-10-2003 15:57 |
