Go to Post It'd be nice to have some more data to look at, I like data - Aren_Hill [more]
Unread 09-01-2008, 13:58
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: KITBOT assmenly
Unfortunately, as of last night, the chassis assembly instructions do not provide any clues on how to mount the Tough box transmissions. You will find included in your Kit o parts (look at the annotated checklist) some aluminum mounting brackets for the transmissions. Let me see if I can describe how to use them without a picture.
1 bracket is narrow, the other is broad and flat with 45 degree bends on either end. The big bracket is called the top mounting bracket. If you are going to drive your wheels with a chain, and your wheels will be mounted in standard positions (like in the documentation) then you will want to mount the transmissons so that the output shafts hang over where the wheels are. The big mount bracket has small holes on one tab that align with the upper transmission housing bolts (positioned at the output shaft side of the transmission). If your transmission is placed as described above, this should cause the other end of the big mounting bracket to bridge the wheel well at a 45 degree angle and mate smoothly with the outter frame bar.
The smaller bottom bracket also as two smaller holes on one side that align with the transmission mounting bolts. After figuring out how to position the BIG bracket, the smaller one should be obvious.
Did this help at all? Maybe someone can post a picture to erase my 1000 words!
Unread 09-01-2008, 15:32
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Re: KITBOT assmenly
This post can help to explain one way of mounting the Toughboxes.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
kitbot stuff..? naroarr Inventor 1 17-01-2007 16:59
Kitbot chassis in Pro/E Billfred Inventor 1 27-02-2006 22:19
Tips for KitBot generalbrando Kit & Additional Hardware 15 15-01-2006 21:15
Kitbot transmission plate Andrew Schuetze Technical Discussion 9 30-01-2005 14:34
