Go to Post Public Service Announcement: Pressing the spacebar when the robot is enabled isn't nearly as funny the forty-second time. - Taylor [more]
Unread 09-01-2008, 14:18
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Re: the main code
The while loop continues to loop while the condition in the () remains true. It is checked at the beginning of the loop. (There is another kind of while loop that checks at the end of the loop.)
So a while(true) -- or a while(1) -- or a while (1==1) -- continues forever until an outside condition stops it, such as the field gets turned off at the end of a match, or something inside the loop jumps out of the loop (not likely). It's a simple way of letting your code run forever until you turn it off.
Unread 09-01-2008, 19:08
MARS-CJ's Avatar
MARS-CJ MARS-CJ is offline
AKA: Carl Jalm
FRC #1523 (M.A.R.S.)
Team Role: Scout
MARS-CJ is on a distinguished road
Send a message via AIM to MARS-CJ
Re: the main code
That'd be a do-while loop.
do {
    printf("Looping...\n");
} while(x == 2);
Unread 09-01-2008, 19:28
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: the main code
as a side note, try to avoid loops in your custom code, as they tend to cause the processor to crash.
Unread 09-01-2008, 21:31
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: the main code
Only if they don't terminate properly.
If you write them carefully, you shouldn't have too much trouble.
Unread 10-01-2008, 06:44
FRC #1153
Rookie Year: 1900
Re: the main code
Yeah, I get the different loops syntax mixed up. Be thankful I remember that I know they are there, and I know where to look them up!
I'm curious how far can you stretch the loop until you really ought to break out. I had a loop that took (I forget) 16-20 sonar readings in one pass of the code, then the next pass start printf'ing them out. The printf is much slower and I didn't try doing it in one pass, and as it turns out, the sonar readings take more time than one pass apiece.
Unread 10-01-2008, 08:26
Roni2230 Roni2230 is offline
FRC #2230
Roni2230 is an unknown quantity at this point
Re: the main code
Thank YOU every one.
But what is the spin per sec?
I think its 62...
I am not sure...
Thank YOU from Israel!!
Unread 10-01-2008, 10:44
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: the main code
The main while(1){} in the default code without any user changes is executed about 830,000 times a second. Once you start adding your own code then it will get slower.[1]
The inner loop via the new spi data check is executed at most ~38 times per second (new data from the operator interface is available every 26.2ms).
The best thing to do would be to read some of the documentation at the ifirobotics site on the structure of the main loop.
And while it is true you can get the red light of death if you make your program execution path too long -- there is an easy way to avoid this ala EasyC/WPILIB. Namely you move the getdata/putdata into an event routine that is run during the system clock interrupt. Then it doesn't matter how long your program execution path is unless you really do something nasty to hang the processor so it won't service interrupts.
[1] the default code path is roughly 12 instruction cycles long but this doesn't account for the background global interrupt routine that is handling the SPI bus transfers of data between the master and user processors, nor the Process_Data_From_Master_uP routine that is executed 38 times per second, so maybe it has an average code path length of 20 instruction cycles in the default code and it only runs 500,000 times per second.
Unread 10-01-2008, 12:14
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Re: the main code
I think its 62...
I am not sure...
This depends on how much code you have. If the spin() loop is empty, it will get called thousands of times. If it does a lot of calculations, it might only get called tens of times. If you are processing lots of interrupts, that will also slow down the spin() loop.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
changing main.c 3dude_2231 Programming 15 21-02-2007 01:54
main.c 6600gt Programming 3 29-08-2006 02:19
Editing Main.c Astronouth7303 Programming 22 20-02-2004 16:45
Main Stage archiver 2001 3 24-06-2002 03:06
main driver Kaitlin Palmer Off-Season Events 0 09-04-2002 21:26
