Re: Cricle base vs. Rectangle base
What advantage do you think a circular base will give you? What disadvantages do you think it will give you?
Have you considered other shapes? Perhaps a triangular or hexagonal base? I would think that a circular base would be harder to manufacture, due to not having straight lines. Another shape, like a hexagon, might give you a close-enough approximation to a circle to gain whatever advantage you expect to get from a circular base, while still being relatively easy to cut pieces for.
Personally, I think that since most robots will be rectangles of approximately the same dimensions, it would be nice to see some variety out there. I recall seeing one robot a few years ago (2002?), which was based on a triangular base. It had three wheels, 120 degrees apart from each other, and functioned as an omni-drive. I've heard of another similar drive which, in 2003, drove and turned so fast it would bank up on only 2 wheels.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
