Go to Post Quoting Fred Durst--"Bring it on." - Billfred [more]
Unread 07-01-2008, 09:50
neilcooper neilcooper is offline
neilcooper will become famous soon enough
2 way IR communication?
Is this allowed if its not intended to jam other robots?
Also would a multiplexer be a bad idea for it because it only runs at 100 ms?
Unread 09-01-2008, 16:39
interfect interfect is offline
FRC #2022
interfect will become famous soon enough
Re: 2 way IR communication?
I think the rules basically lock you down to four static commands to the robot. So no magic fancy control systems are allowed. I'm not sure what you'd use two-way communication for, but I don't think you can have it.
Unread 09-01-2008, 16:44
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Send commands to the OI for it's LEDs, get the drivers to relay stuff to the robotcoach. The OI is able to receive information during autonomous.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 09-01-2008, 16:47
FRC #2022
If you really need to get info to the robocoach, put some big lights on top of the robot.
Unread 09-01-2008, 20:14
Check the manual for answers to this and other questions.
Originally Posted by <R65>
SIGNALING DEVICES shall:...not receive any input or feedback directly from the ROBOT (the ROBOCOACH may receive feedback from the ROBOT and use it to control the SIGNALING DEVICE)
Two-way IR communication would violate this rule.
Data Communication coreyk IT / Communications 4 02-05-2005 19:09
pic: Another one from way, WAY up CD47-Bot Extra Discussion 18 01-05-2004 02:31
Section 2 - Communication team222badbrad General Forum 2 08-01-2004 20:03
Serial Communication in C++ Adam Shapiro Programming 8 21-01-2003 12:49
organized way of communication with FIRST? archiver 2001 0 24-06-2002 04:20
