Re: pic: 114; How We Roll
Looks robust!
/Wishes 1757 had CAD experience and a shop; looks like we're running a KOP chassis again... |
Wait, what happened to the outback tracks you were so adamant about using?
hey what r the advantages of 4 wheel drive that 2 wheels drive couldnt acomplish
Uh. This isn't a 4 wheel drive, it's a 6 wheel. As for the 4 wheel v. 2 wheel, please search the forum and read the many threads created about this topic. |
Nice, but where are the CIM's pinion gears?
I would comment on the design itself, but I can't really think of much to add. It is a proven design. To tell the truth, what I really want to post about is the picture itself. I find that when teams go for a photorealistic render, it tends to look like a pale/too shiny imitation of nature. Similarly, the plain old screenshots tend to look bad to me because they just look unfinished. However, this picture I like; it doesn't look like a failed job at photorealism, but, at the same time, it also it doesn't look like some random screenshot. Nice work! |
are all 6 wheels being powered?
and is your frame welded together or bolted? |
#7
As for the pinion gears, it's a bad habit of mine to not put them in. I need to work on not doing that anymore... All 6 wheels are powered. The frame will be welded. (you'd see bolts if it weren't) Plus, I'm a fan of welding, as it's lighter than bolts, as well as a proven method. |
#8
looks nice... wishing that 1825 had money to make something like this... looks like we are going to have to use the KOP chassis... again... but man if we had money i would have a real good one done with CAD oh well have fun!!!
#9
The setup you made last year was very maneuverable and I can't wait to see this one in action!
not THAT long until competition ![]() |
#10
Yeah, but it's TOO long till competition! This year should actually be more maneuverable, slightly. Also about a third less weight taken up by the drive base. Woo. Oh, and I lowered the CG by 2 inches. Now our robot should be able to go to 70 degrees off vertical and pop up, instead of the 60 it was last year.
| pic: 114: How we roll | CraigHickman | Extra Discussion | 27 | 19-04-2007 20:46 |
| pic: It's how we "Roll" | billbo911 | Extra Discussion | 9 | 10-04-2007 14:51 |
| pic: 114 Tread V 2.0 | CraigHickman | Extra Discussion | 4 | 08-01-2007 01:34 |
| pic: 114: Stripped! | CraigHickman | Robot Showcase | 5 | 04-04-2006 23:49 |
| Tank treads, how we roll | plutonium83 | General Forum | 6 | 08-01-2006 14:51 |
