Go to Post When you are able to get inside their heads, you will either... or.. B) Learn way to much, and end up running away screaming. - Either way, it'll be a learning experience. - Elgin Clock [more]
Unread 09-01-2008, 17:37
Bronson's Avatar
Bronson Bronson is offline
Programmer/Electrician (Plus More)
FRC #2077 (Laser Robotics)
Bronson is an unknown quantity at this point
Help With Gyro
Maybe my team misunderstood the manual, but it sounds like the yaw-rate gyro which comes with the crates is meant to detect temeperature as well as "Yaw". Also, the accuracy factor listed on the site is +/- 300 degrees. How does that work?
Robotics isn't a club, it's a way of life.
Team 2077 Slogan: Design, Build, Dew.
Unread 09-01-2008, 17:45
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Help With Gyro
Originally Posted by Bronson View Post
Maybe my team misunderstood the manual, but it sounds like the yaw-rate gyro which comes with the crates is meant to detect temperature as well as "Yaw". Also, the accuracy factor listed on the site is +/- 300 degrees. How does that work?
The gyro can indeed detect temperature. Why? Because temperature has an effect on the gyro's ability to determine rotation rate. It allows code to very accurately interpret the values the gyro is sending out. Do we need to be concerned with this? IMHO, not really.
The gyro in the KOP only is guaranteed to track up to +/- 80 deg/sec, not +/-300 deg/sec, though that would be really nice.
Unread 09-01-2008, 17:51
Bronson's Avatar
Re: Help With Gyro
Thanks.
Unread 10-01-2008, 21:09
AndrewN's Avatar
AndrewN AndrewN is offline
it's alive!
AKA: Andrew Nicholson
FRC #1778 (Chill Out)
AndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really nice
Re: Help With Gyro
The mechanism inside the chip is sensitive to temperature.
The chips were designed to be used in aviation where temperature drops the higher you climb till you are operating in sub-freezing temps.
Providing the temperature of the chip allows the software to correct the values from the twist sensor to give adjusted yaw rates.
For the purposes of the 2.5 minute game on a level playing field indoors, doing the bias calculation at the start is good enough. Ignore the temperature.
The temperature will remain stable enough - unless you have it mounted right next to a heater.
Temperature is one factor that changes from day to day and why storing the bias in eprom is a bad idea.
BTW: Remember output T - Temperature, it's the other one you want.
Andrew Nicholson
2011 FRC Robot Inspector (Seattle, Portland)
Mentor FRC 1778 "Chill Out", FTC 3018, 3940 "Hawks", 4434 "Heat Misers"
"Everything should be made as simple as possible, but no simpler."
Drifting Gyro with EasyC SgtMillhouse648 Programming 6 15-08-2007 12:17
Need help with gyro turn magical hands Programming 2 11-03-2007 21:53
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Need help with Gyro = Analog Devices ADXRS150EB Jack Jones Technical Discussion 9 18-07-2005 07:00
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
