Go to Post I keep on accidently seeing (and pronouncing) it as Chef Deli. - JJG13 [more]
Unread 09-01-2008, 18:36
Transporter1717 Transporter1717 is offline
FRC #1717
Transporter1717 is an unknown quantity at this point
Kit bot wheels and chassis assembly
It has come to my attention that while assembling our kit bot chassis and andy mark wheels. We are just using the kit chassis and wheels or prototyping and my team is wondering if there is a quick ans simple solution to make an axle fit through the 3/8 inch holes on the chassis and the 1/2 inch holes on the wheels.
Unread 09-01-2008, 18:53
Gdeaver Gdeaver is offline
FRC #1640
Re: Kit bot wheels and chassis assembly
Buy 1.125 OD by 3/8" Bearings. Use a grade 8 3/8" Bolt.
Unread 09-01-2008, 19:44
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
what we did was drill out the holes to 5/8" and use an 1/2" ID and 5/8" OD flange bearing. The only thing that made we question this was that it removes the metal around the lowered hole completely in a small section. The bearing takes care of that load. It worked without problems for a regional and an off season event. It's still running now.
Unread 09-01-2008, 19:51
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
All that i did with our six wheel drive was to drill out the holes to 1/2 in. and run a 1/2 bolt through with spacers between the frame rail and the wheel bearing. It worked great. I have used pillow block bearings and shafts also.
kit bot assembly plans falconmaster General Forum 4 09-01-2008 18:53
please post hints in how to help improve first bot chassis and which ones they r ^^ robotchibi General Forum 8 01-11-2007 16:06
Kit Drive Assembly Allison K Kit & Additional Hardware 5 11-01-2005 17:52
Warning: Error in beacon assembly directions included in the kit! Dave Flowerday Electrical 11 27-01-2004 16:36
Wanted: 2 Kit Wheels tenfour General Forum 2 18-01-2004 22:02
