Go to Post The 48 defensive DNA lies dormant in the drive train. It's impossible to forget. - Koko Ed [more]
Unread 14-05-2007, 21:33
brummer_13 brummer_13 is offline
FRC #1501 (Thrust)
brummer_13 is an unknown quantity at this point
3DS Max Help
Ok, im using 3ds max for a school project and i have accedently done something. i have somehow locked all the figures and objests i import onto the orgin. if i make a just a plain circle, the center of the circle is the orgin and i am unable to move it. how can i fix it?
Unread 16-05-2007, 21:38
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: 3DS Max Help
try hitting space bar. That unlocks things. Other than that i cant visualize your problem. Can you explain some more?
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 08-01-2008, 18:10
FRC #1501 (Thrust)
Re: 3DS Max Help
that didnt help. when ever i try to place a circle for example, it is automatically centered on the orgin. and that would be ok but after that circle is created, i cant move that circle anywhere.
Unread 08-01-2008, 18:50
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Re: 3DS Max Help
It might have something to do with the Transform Controller.
1. Select your object & click the Motion Tab (wheel icon)
2. Under Assign Controller choose Transformosition/Rotation/Scale
3. Click the little square icon w/the question mark
4. Is the "Position/Rotation/Scale" controller checked? If not, it should be, and click the 'Make Default" button.
Let us know if this helps!
Unread 09-01-2008, 16:49
FRC #1501 (Thrust)
Re: 3DS Max Help
no that didn't help. it was already checked. the worst part is that i uninstalled and reinstalled 3ds max and the problem was still there it didn't get reset at all. could it somehow be a problem with my computer? i'm running it on a laptop (that can handle it) but the other copies i have access to are on slower desktops that have not had this problem.
Unread 09-01-2008, 19:27
AKA: Kevin Thorp
Re: 3DS Max Help
Sorry. I know you must be frustrated.
On a 3ds Max forum I read about a guy having an identical problem with an older version of Max. He fixed it by exiting the program & deleting his max.ini file. When he restarted Max it created a new "clean" ini file and his new objects behaved normally.
I know you reinstalled Max. I don't know if that overwrites an existing ini file.
If this doesn't help you might try these forums:
www.maxforums.org
http://area.autodesk.com
Search the archives first, then if you can't find a solution post a new question. Try to be very specific in the subject heading. it'll get a quicker response.
Unread 09-01-2008, 22:58
FRC #1501 (Thrust)
Re: 3DS Max Help
wow that helped. thank you. thank you very much! if you ever happen to findout why that happens that would also be very helpful so i wont have to delete all my settings when it happens again. but this is great.
3ds Max Help! SamC 3D Animation and Competition 12 01-04-2006 20:23
3ds max help reventlov 3D Animation and Competition 7 20-02-2005 00:30
3ds max help reventlov Inventor 0 08-02-2005 17:01
3ds max 6 help superbeano2004 3D Animation and Competition 6 21-10-2004 20:42
HELP!- installing 3DS MAX HUMMERIC 3D Animation and Competition 2 16-02-2003 01:11
