Go to Post The best legacy of this little machine is the inspiration she provided to a whole generation of future explorers who witnessed the unveiling of a planet through the eyes of a robot. - dlavery [more]
Unread 09-01-2008, 18:57
Lucretius Lucretius is offline
#395 Mentor, #1884 Alumnus
FRC #0395 (2 Train Robotics)
Lucretius is an unknown quantity at this point
Terminal in Linux?
We're an EEEPC running Xandros to compile (with a makefile) and upload code to the robot controller. picloader works quite well, while IFI Loader (under Wine) does not at all. How could we get a terminal working so we can see any and all printf's? We're using a Keyspan USB-to-serial adapter.
Unread 09-01-2008, 19:40
shtylman shtylman is offline
some sort of programmer
FRC #2420
shtylman has a spectacular aura aboutshtylman has a spectacular aura about
Re: Terminal in Linux?
I created an IFI Loader java clone.
http://shtylman.com/jifi/
It has a terminal display as well. That might be able to help you out.
Unread 09-01-2008, 22:46
interfect interfect is offline
FRC #2022
interfect will become famous soon enough
Try picreader (also in pictools). It gives you a (CLI) console like IFI Loader.
Unread 09-01-2008, 23:03
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
minicom?
theres lots of terminal clones for linux.
Unread 10-01-2008, 10:57
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Yeah, minicom works great. Just make sure you set it up correctly first (8 data bits, no parity, 1 stop bit, no flow control). Your serial device will be /dev/ttyS0 or /dev/ttyS1 for a normal serial port, and /dev/ttyUSB0 for a USB serial adapter. Don't worry about baud rate, the FRC boot loader will handle it (although 115200 baud is fastest).
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 10-01-2008, 12:18
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
The easiest way (if you only want to see printf()s, not write back to the RC over the serial port), is to just do "cat /dev/ttyS0" (or whatever serial port you've been using, possibly /dev/ttyUSB0).
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Terminal Block Big-Bird08 Technical Discussion 2 29-01-2007 19:10
Terminal Window teh_pwnerer795 Programming 1 02-01-2007 00:21
Terminal Window Idaman323 Programming 0 20-02-2006 19:28
Is Terminal Window Evil? Fat Alex Programming 1 20-07-2004 10:57
Terminal Screw Strips? Jay05 Electrical 2 09-03-2003 21:48
