Go to Post I don't think Dean Kamen ever recieved a real degree. That doesn't make him any less of an engineer.:) - Adam Y. [more]
Unread 09-01-2008, 19:43
jasonpeinko jasonpeinko is offline
FRC #1087
jasonpeinko is an unknown quantity at this point
Re: IFIloader and usb converter does not work
I get an error,
C:\Documents and Settings\Jason\Desktop\jifi\Jifi.exe
This application has failed to start because the application configuration is incorret. Reinstalling the application may fix this probelm
Using a USB to 15 pin converter gillejr Control System 7 29-01-2007 20:44
Does EasyC Pro work with the USB-Chicklet? lightning_blast Programming 6 20-01-2007 23:39
USB-Serial Adapter and IFILoader under Linux Venkatesh Programming 3 03-12-2006 22:52
Arcade Mode (12) does NOT work jakk Programming 2 10-07-2006 19:27
Chaos theory does not work!!!!! S9ar7acu3 General Forum 3 09-02-2003 11:46
