Go to Post I bet Andy Baker would totally own JVN in a 1v1 dodgeball fight. - Greg Marra [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 23-07-2007, 13:46
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Combining many SLDDRW files into a single file
Does anyone know if it's possible -- and if so, how I can -- combine many separate Solidworks drawing files into a single Solidworks drawing file with multiple sheets?
I'm trying to clean up some sheet metal work by combining the parts' pattern drawings with its bent up drawings.
Thanks.
--Madison--
...down at the Ozdust!
Unread 09-01-2008, 20:23
NHPilot NHPilot is offline
NHPilot is an unknown quantity at this point
Re: Combining many SLDDRW files into a single file
Add a second sheet to the drawing you're looking to make common. Go to the drawing you want to combine from and 'CTRL Copy' all the views, then 'paste' them onto the 2nd sheet you created on the first drawing. Repeat this as many times as necessary.
One thing to keep in mind, in my experience, adding many sheets starts to slow things down, especially if you're dealing with assemblies.
Help! making an inventor file into an autodesk file kjhobin Inventor 5 19-03-2006 23:04
I cant get my program into a hex file Serge Programming 8 17-02-2006 03:28
Combining multiple objects in different files into the same scene and file? DinkyDogg 3D Animation and Competition 8 19-02-2005 19:14
Black and white image files into AutoCAD? A-Baum Inventor 7 24-04-2004 00:43
How do we convert a modified user routines file into a valid .HEX file HuskieRobotics Programming 13 28-02-2004 12:12
