Go to Post It is easy to be righteous on Chief Delphi, and harder to implement in life. - DonRotolo [more]
Unread 09-01-2008, 20:50
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Using sensors
Here are a few brief summaries of some common types of sensors used in FRC applications:
Limit switch: can be used for simple control of manipulators, to prevent them from driving past the mechanical limits of the system. Digital signal.
Light sensor: can be used to follow lines, detect colors, and be used to create an optical encoder to sense rotation by pointing it at a disc with alternating white and black stripes. Analog signal.
IR range sensor: used to measure distance. Analog signal.
Ultrasonic sensor: used to measure distance. Needs interrupts to work correctly.
Hall effect sensor: detects ferrous materials, such as the teeth on a steel gear or sprocket. Can be used to sense gear teeth passing by, to work as an encoder. May need interrupts.
Encoder: generic term for sensor that measures rotation; with a known wheel size can be used to gauge how far robot has driven/spun. Generally needs interrupts to work correctly.
Quadrature Encoder: Basically it's a "dual encoder" that can sense rotation as well as which direction it is rotating in.
Accelerometer: measures acceleration. Can be used to find abrupt changes in speed, or for inertial navigation.
Gyro: measures change in angle. Can be used in place of potentiometer if space to mount one is not available. Can also be used to sense how far a robot has turned.
Potentiometer: Variable resistor used to detect rotation over a limited range, commonly about 270o. Can be used on arms, to know exactly where the arm is. Analog signal.
Art Dutra IV
世上无难事,只怕有心人.
Using gyro.c with other analog sensors no go Astronouth7303 Programming 17 03-01-2006 21:04
Using gyro with other analog sensors...again demerski Programming 0 19-02-2005 08:23
Using Sensors thoughtful Programming 11 16-12-2003 10:28
Anyone using sensors??? Willum Robot Showcase 42 25-02-2003 18:57
Is anybody using the sensors? Jeremy L Rules/Strategy 26 03-03-2002 22:42
