Go to Post When's the last time you called up FIRST headquarters just to say thanks? Or saw a volunteer at a regional and said, 'Hey, you're doing a really great job here. Thank you for everything you're doing in your spare time.' - Amanda Morrison [more]
Unread 09-01-2008, 21:44
jimbot's Avatar
jimbot jimbot is offline
FRC #2083
jimbot will become famous soon enoughjimbot will become famous soon enough
What is hurdal exactly?
HURDLE: When a TRACKBALL CROSSES a FINISH LINE while passing above the OVERPASS
and then contacts either the floor or another ROBOT before re-contacting the originating ROBOT.
HURDLING: The act of completing a HURDLE. To be considered in the process of HURDLING,
the ROBOT must:
be in its own HOME STRETCH, and
be in POSSESSION of a TRACKBALL, and
be moving toward the OVERPASS and/or elevating the TRACKBALL so that the top of the
TRACKBALL is higher than the LANE DIVIDER.
THe top part of this forum is what i am worried about. It states that for a hurdle to occur, the TRACKBALL must touch the ground or another robot before it touches your robot after crossing the finishline. Does this mean that If you carry the ball across the finishline/overpass do you loose the points/hurdle? My team is worried because if you must toss the ball over, we would struggle to build an arm to do this.
Unread 09-01-2008, 21:46
Re: What is hurdal exactly?
the ROBOT must:
Have you seen Update #1 yet? If not, then you should. It clarifies that the carrying (over the overpass) will score, but the carrying under the overpass will not.
So, What exactly is Fantasy FIRST? Elgin Clock Fantasy FIRST 37 15-08-2013 19:28
What exactly is a servo horn? Elgin Clock Motors 5 24-07-2006 19:48
FAHA: What exactly is a secret? Ken Leung General Forum 6 12-02-2004 19:55
Yeah- what exactly is meant by 'best'? archiver 2000 2 23-06-2002 23:10
