Go to Post if it was up to me, id just get one of those spinning BINGO things and do it that way - dodar [more]
Unread 09-01-2008, 21:45
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Need tips on wiring the IR board
Hey guys, we started hooking up the IR board yesterday, and are looking for a bit of help.
We got all the appropriate wires connected, but rather messily. We soldered the pwm cables and battery wires to the appropriate pins using the ribbon cable, but... The pwm cables are about twice as large as the ribbon, cables, and theres one wire on the pwm cables that is unused (white wire on each pwm cable connects to one each of the signal outputs, each black is connected to common ground, red is hanging there). The battery wires are enormous compared to the ribbon cable (using standard backup battery + wires).
We currently have a bunch of wires going all over the place, of which all connections are soldered together then electrical taped.
Did we do this right, and is there some way to clean it up?
I'll hopefully get a picture of this tomorrow to help.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 09-01-2008, 22:08
Re: Need tips on wiring the IR board
You can "cheat" a little and use only two PWM cables. One of them will have the black and white wires for ground and one signal, with the red +5 unused. The other will carry the remaining three signals, and plug into the Robot Controller "sideways" across where the white pin of three connectors would usually go.
If we use the IR detector board, I intend to make a small "wiring concentrator" board to go next to it. All the digital input and power connections will go to that board, which will have a ribbon cable connector to bring all the signals to the matching connector on the IR board.
Unread 09-01-2008, 22:14
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
What we did was wire the power and ground to the fuse board exactly like the RC itseld, then just connected each signal wire to a signal port on the digital inputs. It works (for now)
Unread 09-01-2008, 22:27
sayso_411's Avatar
sayso_411 sayso_411 is offline
10 Years of Sparky!
AKA: Shaav
FRC #0384 (Sparky)
sayso_411 can only hope to improve
We hooked up everything correctly and programmed the robot to do simple functions but i m skeptical how RoboCoach is going to effect the game this year
Unread 12-01-2008, 18:34
JohnC's Avatar
JohnC JohnC is offline
my other name is nigel
FRC #0360 (360 Revolution)
JohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the roughJohnC is a jewel in the rough
Send a message via AIM to JohnC
This may help:
http://www.chiefdelphi.com/forums/sh...12&postcount=4
What place are we at? ... TODAI!
pic: Team 668 Wiring Board burkechrs1 Extra Discussion 4 06-02-2007 01:56
I need the 2006 Wiring Schematic Diagram SkD_nub Electrical 2 06-02-2006 14:46
New at this and need some helpful tips Nathan B. Technical Discussion 5 06-01-2005 21:04
need some help with the OI, and wiring a display pryoplasm Control System 8 10-03-2004 20:46
I need tips on Starting a New Team. Rook Starting New Teams 6 25-03-2003 11:19
