Go to Post I want to win, but I want to beat my opponent when they are at their best. - wilsonmw04 [more]
Unread 08-01-2008, 19:39
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
Trig functions in C18 3.10
Hi,
I am aware that numerous trig lookup tables and algorithms are available for the RC. However, as far as I can tell, none of them are compatible with Kevin Watson's new code.
Does anyone know of a method to calculate trig functions that works under the new version of C18?
Thanks,
David
Team 1751
Unread 08-01-2008, 20:59
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Trig functions in C18 3.10
Can you point me toward code that doesn't work? I'll have a look to see what it would take to get it working.
Unless you need to do hundreds of trig calculations per second, I would just go ahead and use the built-in functions. If you're the adventurous type and just want to do it yourself, you could very easily get my eeprom code code moved over and then use the trig table generation and lookup code I wrote a few years back.
-Kevin
Kevin Watson
http://kevin.org
Unread 08-01-2008, 21:09
MIT '14
The code in this whitepaper doesn't seem to compile correctly.
-David
Unread 08-01-2008, 22:22
FRC #2429
-David
It compiles for me using the attached file that calls sin().
-Kevin
Kevin Watson
http://kevin.org
Unread 09-01-2008, 10:54
MIT '14
Sorry, I linked to an old version of the math library.
The updated library is here.
Thanks,
David
Unread 09-01-2008, 21:54
MIT '14
Just to clarify, the new version does NOT compile under C18 3.10. (My previous post was a bit unclear).
Unread 11-01-2008, 19:06
psh psh is offline
FRC #0166 (Chop Shop)
psh is on a distinguished road
From experience we stay away from PIC floating point in our team. Its emulated, bloated and problematic to debug. It was even worse in the 2004 and 2005 years when the processors only had 32KB.
How widespread is the use of floating point by the teams out there?
>Per
Unread 11-01-2008, 20:38
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
We avoid it if at all possible, and never once have we found it impossible to avoid. In short, we haven't used it. We just make sure that we multiply two integers before diving them (ex in a PID calculation with Kp being 33 / 100 we do 33 * delta / 100 rather than 33 / 100 * delta).
Unread 11-01-2008, 21:33
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
In recent years, Team 95 has been around 50/50. Two years ago we prototyped an omnidrive that worked in field coordinates, and we did sin(), cos(), asin(), and acos() every loop, with no problems.
And last year, our infrared ranging system used lots of floating point as well, with no real problems, although I did help the students develop a fixed-point equivalent (we never subbed it in, however).
Unread 08-02-2008, 09:33
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
did this ever get resolved? Could someone point me in the direction of one that does work with the new code?
A2D Solving the Imaginary Error Function...
Trig. Functions in EasyC miketwalker FIRST Tech Challenge 5 07-12-2006 23:27
speed of math.h trig functions? Jared Russell Programming 4 07-02-2006 07:13
Trig functions and type conversion kaszeta Programming 6 14-01-2006 23:34
Trig archiver 2001 4 23-06-2002 23:14
Return of the Inverse Trig Functions Leo M Programming 3 24-01-2002 08:12
