Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 07-01-2008, 21:59
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
WPILib Use Help
Okay, so we are just starting WPILib use on our team, and it looks great. However, we are having a couple problems, like how to use some features. I am trying to use the LEDs on the OI (Pwm1_green, for example). I tried using that like I did before, and it didn't work, and I acan't find the function for it. Is there a list of functions and there use out there, because there isn't one in the verison of the papers I got. Also, the SetCompetitionMode function is generateing a warning saying it has no prototype, but I can see it in BuiltIns.h, and API.h is included in that, and BuiltIns.h is included in main. Any help would be great. Here is the basic code I wrote to build off, which aside from the prototype warning compiled clean:
Main.c:
//Include features
#include "BuiltIns.h"
#include "Constants_Control.h"
//Setup competition mode, called first
void IO_Initialization(void)
//Set to automatic competition mode handling
SetCompetitionMode(AUTO_FIELD);
//Initialize: run at robot startup regradless of mode
void Initialize(void)
//Note: will switch between auto and operator automatically,
//even if the code is currently in an infinite loop
//Autonomous: run at field control enable
void Autonomous(void)
while(INFINITE)
//OperatorControl: Teleoperated period
void OperatorControl(void)
//Main: Satifies call requiremen only, unused
void main(void)
My only custom file s far, ConstantsandControl.h:
#ifndef Constants_Control
#define Constants_Control
//Constants
#define AUTO_FIELD 1
#define INFINITE 1
//Controls
#endif
End Code
Any help wuld be greatly appreciated
Unread 09-01-2008, 21:50
AKA: Brad
#0190 ( Gompei and the Herd)
Re: WPILib Use Help
Ryan -
I tried compiling the code that you listed and didn't get the warning about SetCompetitionMode. What you had seemed right, maybe you were building a Vex version of the program. In the Vex version there are two arguments, the first being the autonomous period time and the second the operator control period.
Actually, that might explain why the SetOILED functions aren't working. Those are also missing from the Vex version since there are no IO LEDs.
Can you verify that you have defined _FRC_BOARD in your project somewhere. That's the preprocessor symbol that includes the FRC stuff.
Brad
Brad Miller
Robotics Resource Center
Unread 09-01-2008, 22:16
Ryan O's Avatar
Re: WPILib Use Help
It's in the provided headers, but do I need to add a line in user-written code somewhere to tell it which? It never asked anything about that. That would explain it though.
Unread 13-01-2008, 11:24
Ryan O's Avatar
Re: WPILib Use Help
Ok, got it to work now. I didn't realize you could #define symbols like that outside their headers, and I thought you had to have different syntax. Thanks for the help, problay wouldn't have figured it out until the robot met a wall somewhere
Use of printf in WPILib koenig3456 Programming 2 06-03-2006 07:21
could use some programming help. mtaylor Programming 2 23-01-2005 10:54
could use some programming help. mtaylor Technical Discussion 2 23-01-2005 10:54
iF could use some help Nick Mac FIRST-related Organizations 0 12-05-2003 21:26
anyone use an arm to help balance archiver 2001 8 24-06-2002 02:46
