Go to Post Obligatory warning: School comes first. If you have to choose between doing homework and going to a build season meeting, do the homework. - Billfred [more]
Unread 09-01-2008, 23:09
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
pic: 2008 drivetrain 1771
Unread 09-01-2008, 23:10
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Re: pic: 2008 drivetrain 1771
is that c-channel going to be the only thing holding the arm. it seems to me it needs more support.
Unread 09-01-2008, 23:25
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Get out of my head!
Unread 09-01-2008, 23:28
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Looks like you could really use another crossbar for lateral support. I'm assuming you will have some sort of alternate support for the column.
What is the weight and are there any real advantages over the kitbot frame?
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 10-01-2008, 00:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
One word. Electronics.
Unless the back half is unoccupied and can be used, I think you've left your electronics team quite the challenge.
Unread 10-01-2008, 10:02
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
Are the other four wheels going to be powered?
What was your thought process for uses six regular wheels?
Looks great, wish our team was that far.
Design. Build. Dew.
Unread 10-01-2008, 11:02
Mr.Rush Mr.Rush is offline
AKA: Braden Rush
FRC #0401
Mr.Rush is on a distinguished road
they stated in the caption that only the center two wheels are powered, and it seems that there is plenty of room on this bot for the 6 or so victors,the battery, the distribution block, as well as the "brain".....the only issue they might run into is if they want to make a solid board.
Unread 10-01-2008, 11:05
AKA: Sean
The c channel will not be the only thing holding up the arm. There will be more braces down low and Im also thinking 2 braces coming off the arm to the base forming a huge triangle. There will also be another brace in the front to stiffen things up. As far as electronics they can be put just about any where in there. We really don't have anything else going in...maybe the compressor? Also I want to mount the controller and some things vertically.
The advantage of this over a kit bot is obviously strength and it is perfectly suited for our version of the game. Also there are little things like tensioning slots and such which allows us to run #25 chain without worry.
We used the standard wheels mainly to save weight and they are still fairly grippy. Also the 6" diameter wheels give us about a 9.5fps speed which we are going for.
Mentor 2415
Unread 10-01-2008, 11:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Looks like a very familiar design.
We've used a similar configuration with great sucess for a number of years now. (3 that I can remember at least)
That was our 2004 bot taken apart for offseason testing.
If you need any pointers, or general advice just feel free to ask.
Unread 10-01-2008, 11:55
AKA: Sean
Thanks everyone. Hopefully it will work well. I've been trying to build a drivetrain like this for the past 3 years and I think it's finally going to happen
Mentor 2415
pic: 1683 drivetrain 1 sdcantrell56 Extra Discussion 11 01-02-2007 11:24
pic: Early Drivetrain Gabriel Mendez Robot Showcase 10 28-01-2006 00:50
pic: Drivetrain Preview Nuttyman54 Extra Discussion 2 17-02-2005 21:47
pic: 254 Drivetrain CD47-Bot Robot Showcase 41 05-05-2004 09:36
pic: drivetrain CD47-Bot Robot Showcase 3 07-03-2004 20:35
