Go to Post Robotics season has monopolized my time for the past several weeks so I have not been keeping up with Segway news lately - Stu Bloom [more]
Unread 09-01-2008, 13:59
mjgard's Avatar
mjgard mjgard is offline
Michael
AKA: Michael Gard
FRC #2844 (Stampede Robotics)
mjgard will become famous soon enough
Toughbox Assembly
Has anyone else had problems assembling the toughbox? I cannot get the large bearing over the large shaft. I tried using force but it barely starts and gets stuck. Any recommendation to getting this piece on. I am afraid if I use to mush force it will get started and I wont be able to get it back off.
Unread 09-01-2008, 14:29
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
Re: Toughbox Assembly
We had difficulty with getting the pins. We had to get extras before we were successful.
Good luck.
We are a Rookie team and the AndyMark Toughbox was our first successful assembly in FIRST.
One thing down and counting.
Unread 09-01-2008, 14:30
Someone else was having trouble with the large bearing. You may need to make sure it's straight first.
Unread 09-01-2008, 14:36
Mike Rush's Avatar
Mike Rush Mike Rush is offline
Somewhat Insightful
FRC #4154 (Perpetual Recursion)
Mike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really nice
We had the same issue with the bearing. It appears to me that the finish on the shaft is not very good. When it was turned to size there are small ridges remaining on the shaft. To correct the problem take some abrasive cloth and remove a small amount of material. I did this on our small lathe using an emory cloth to smooth out the finish. The bearing slips on easily after the finish is improved.
Mike Rush - Engineer/Mentor
Perpetual Recursion (4154)
Arizona Community Team (1492)
2004 AZ Regional Woody Flower's Award
Basha High School & Intel (1456)
Gila Monsters (64)
Awards!?! Too many to list...
Unread 09-01-2008, 14:59
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
We had some trouble too, but I took it to be because of the close tolerance. The bearing has to be perfectly straight to slide on smoothly. A dab of grease on the shaft helps. We also used a deep well socket and tapped gently with a hammer to get it set.
Unread 09-01-2008, 15:08
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
i am having the same problems with it. ty will try these suggestions
Unread 09-01-2008, 15:29
Kyle Love's Avatar
Kyle Love Kyle Love is offline
Support STEM Education
FRC #3301 (Jay County Robotics)
Kyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond reputeKyle Love has a reputation beyond repute
Things that you can do to make the bearing go on to the shaft.
  1. Put a dab of grease on the shaft and "wiggle" the bearing down onto the shaft.
  2. Use emory cloth or scotch brite pad to smooth the surface of the shaft.
***Do not try to lathe down the shafts*** The dimensions of the "trouble" shafts that I have seen do not require more then 5 minutes of scotch brite/ emory cloth work.
Kyle Love
Teams I've been on:
Team 45 - The TechnoKats - Student/Leader/Driver 2004-2007
Team 1646 - Boiler Precision Guessworks - Mentor 2007-2011
Team 3301 - Jay County Robotics - Teacher 2011-Present
Unread 09-01-2008, 15:51
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Toughbox Assembly Video: http://www.youtube.com/watch?v=X0Jpj_aQHYE
-Oris-
Unread 09-01-2008, 18:59
gondorf's Avatar
lathe??? our teacher had to spend about 10 minutes per shaft with a sheet of sandpaper sanding it down to size. but it works now so woot! note: try to sand evenly so it wont turn into a metal oval
Unread 09-01-2008, 21:16
mattotters's Avatar
mattotters mattotters is offline
leadership/fab team
FRC #1228 (A-MERK-IN-INDIANS)
mattotters is an unknown quantity at this point
Send a message via AIM to mattotters
has any one mounted the toughbox? I am a little iffty on how i want to attach it to my frame, suggestions?
No sleep till the new jersey first robotics regional!
Unread 09-01-2008, 22:10
Kyle Love's Avatar
Use the provided transmission mounts with the kit bot.
Kyle Love
Teams I've been on:
Unread 09-01-2008, 23:17
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Today we were looking at assembling them (possibly reducing them to one stage for speed...) and i found that the pinions would not fit on the CIMs. They go on about 1/4", then they get stuck.
Unread 09-01-2008, 23:18
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
-Oris-
This is WAY cutier than the "Baker Act"....nice job Baker family, and Kyle you too!
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 09-01-2008, 23:22
Kyle Love's Avatar
My team had the same problem. You can use a deep well socket and lightly tap the gear down onto the shaft. You can also lightly scotch brite the shaft of the CIM.
Kyle Love
Teams I've been on:
Unread 09-01-2008, 23:23
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
We used a rubber mallet to get the bearing onto the shaft. To get it back off, we put a bolt in the end and put the bearing on top of a vice so that the shaft was inside and the assembly is resting on top. Simply use a mallet to hammer the bearing back off or for a more safe approach (as to not strip any threads), try pushing down on the bolt.
Our toughbox's are assembled nicely and our stuff should be coming any day now so that we can install two more CIM's. Are we supposed to get a shipping confirmation from Andymark? We have not gotten ours yet and we placed our order before 3pm cst on tuesday.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Toughbox mounting bracket models Rob CAD 2 10-01-2008 11:34
Toughbox Assembly Video on YouTube Andy Baker Technical Discussion 25 08-01-2008 15:10
AM Toughbox Model(s) available Ed Sparks CAD 2 08-01-2008 11:15
Assembly? Astronouth7303 Programming 2 12-08-2004 11:30
Importing assembly into an assembly... James Green Inventor 8 22-01-2004 22:17
