Go to Post You can design and theorize all you want, but the sooner you get to testing your ideas and seeing how things actually work, the better off you will be. - Andy Baker [more]
Unread 09-01-2008, 23:26
Re: troque
Originally Posted by jee7s View Post
Also, on a side note, the breakers pop more slowly with repeated usage/popping.
I'd have expected it to be the other way around. Since the breakers are tripped by heating up, shouldn't they be faster to trip if they're already running hot due to repeated overcurrent events?
Unread 09-01-2008, 23:36
jee7s jee7s is online now
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: troque
The slowing was an observation made by one of my fellow engineers/mentors during a motor test. Over repeated breaker trips in a short period the breaker slowed its trip time.
Our best guess is that it has something to do with deformation of the metal strip in the breaker. Heat may make it more malleable, which would reduce the "snap action" of the breaker. The difference is small, but could be significant.
JEE
EDIT: I got some clarification on this, and I misstated the concept. The slowing isn't in the tendency to trip, but in the reset. As was previously stated, the heat makes the trip more sensitive, but it also makes the reset time slower. This means that popping the breaker causes slower reset, disabling the motor for a period of time. AKA...bad idea. My mistake in interpretation.
