Go to Post Here is one really important thing I learnt this season: If you do it for yourself, you ain't gonna make it. If you do it for you're team, You'll make it. - Bharat Nain [more]
  #31   Spotlight this post!
Unread 09-01-2008, 08:43
Storcky's Avatar
Storcky Storcky is offline
FRC #3634 (Hard Botties)
Storcky is on a distinguished road
Re: Help with Omni wheels?
Our team used two omniwheels in the front and two driven traction wheels in the back. The only problem with it was we could not get the omnis to stop turning when we wanted them to. This resulted in the front of the robot continuing to spin after we expected it to. Also, although they were very manuverable, another disadvantage that it was nearly impossible to go straight.
Alum of 1629 - GaCo [2005-2008]
Mentor for 3634 - Hard Botties [2013-2015]
Mentor for 230 - Gaelhawks [2013-2015]
Pittsburgh Regional Planning Committee [2016-?]
  #32   Spotlight this post!
Unread 09-01-2008, 18:43
sweetie_pi sweetie_pi is offline
AKA: Nica
FRC #2189
sweetie_pi is an unknown quantity at this point
thanks for the help that will definately help our plans
  #33   Spotlight this post!
Unread 09-01-2008, 23:43
Darunada Darunada is offline
AKA: Lea Fairbanks
FRC #4598
Darunada is on a distinguished road
Re: Omni wheels?
Originally Posted by tawnos23 View Post
I would suggest to buy metal omniwheels instead of the plastic ones. Our first year with omniwheels we bought the plastic ones, and they broke to pieces during the course of a regional.
WE shattered a junky plastic one all over the field tw years back... and another one demonstrating post-season. The ones currently on the robot aren't very "omni" as most of the small wheels are locked in place by what I assume is a crushing force of the omniwheel plastic colapsing.
That said, last year we used these: http://andymark.biz/am-0097.html
with excellent results, and we will use them again in the future...
  #34   Spotlight this post!
Unread 09-01-2008, 23:55
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I wouldn't say mecanum wheels are better than omni wheels, they are quite different and transfer power differently to the movement of the bot, but I wouldn't call them better, I find the biggest thing about having a strafing bot, is to make sure your driving practices, and uses all the advantages the wheels give you (too often do I see a bot with mecanums or omnis being driving like a 4wd bot, I dislike it lol)
for the record omni and mecanums have slightly different pros and cons about them and depending on how you want to drive it or how skilled your driver is at controlling them, ethier one could seem "better" than the other for your team, I personally perfer omns over mecanums!
  #35   Spotlight this post!
Unread 15-01-2008, 10:39
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Driving Straight is definitely possible with omnis. Arc turning with two back omni can cause your back two omni wheels to fishtail moderately making the robot more difficult to drive. FRC#494 in 2006 used omnis in the corners instead of two omnis on the back side to help control fishtailing. Read the full report on page 160 of the 2006 FIRST Robotics Book.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
  #36   Spotlight this post!
Unread 15-01-2008, 11:07
It sounds like you might have the center of gravity of your robot too far forward for easy controllability. Putting it closer to the traction wheels would help things a lot.
When I joined the TechnoKats as a mentor, my first real programming challenge was to compensate in software for exactly this situation. The code detected the rear wheels' rotation (Banner optical sensors pointing at alternating reflective/nonreflective sections of hub) and adjusted the relative power to the left and right side motors in order to keep the wheel speeds consistent for perfectly straight travel.
Help with Omni-wheels The GarbageMan Kit & Additional Hardware 12 10-04-2007 12:39
can bots with omni wheels capable of going up robots? Tri_Lam Technical Discussion 12 13-01-2007 16:15
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Motors with Omni-Wheels jlewellen Motors 5 11-01-2006 23:24
Omni Wheels edomus General Forum 6 06-02-2004 13:35
