Go to Post You miss 100% of the shots you don't take. - AdamHeard [more]
Unread 10-01-2008, 00:01
Re: A Better Gear Tooth sensor
Originally Posted by Tim Skloss View Post
The Honeywell sensors are easier to mount...
Easier to mount than what? The KOP gearbox has a perfect spot for placing the KOP gear tooth sensor, complete with mounting holes.
Unread 10-01-2008, 08:51
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
The FIRST GTS boards are designed to mount in the gearboxes. The features are provided (although the fasteners are not!). That is where we will use them.
But what about everywhere else on the robot? Placing the fragile board anywhere on the robot other than the inside the protective confines of the gearbox would be inviting disaster. Building protection would be required, but we only have so much time and resources.
The Honeywell sensors are cheap, very reliable, have a very clean signal, easy to use and are nearly bullet-proof.
FIRST Mentor and Team Leader
C.O.R.E 2062 a NASA, GE Volunteers and Rockwell Automation FRC Team
Unread 19-01-2008, 20:05
Tim Skloss's Avatar
Dr. Skloss
FRC #0930
Team Role: Parent
We installed the sensors in the Andy Mark gearboxes today.
You can read about it here.
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Gear Tooth Sensor? Raikon Kit & Additional Hardware 3 09-02-2007 16:40
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Talha Electrical 1 23-01-2006 21:29
Gear Tooth Sensor AMIRAM Electrical 2 22-01-2006 04:09
