Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
  #46   Spotlight this post!
Unread 09-01-2008, 15:00
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Re: pic: Omni Design Trial
Originally Posted by squirrel View Post
So, if you were to set up the wheels to be optimized for straight driving by adjusting the friction to be high enough that the rollers would not be able to roll at normal driving loads, would that make the sideways force vector on the rollers negligible under these conditions? I'm thinking that the inability to overcome static friction would keep the rollers acting like regular tread, and the wheels would indeed act almost like regular wheels under those conditions.
I'm thinking about this as it applies to this game only.
Right, at the cost of even less efficiency going sideways. You could also adjust the roller angle to be closer to an omni wheel to increase the straight driving performance and decrease the side to side performance.
In that paper they talk about adding the feature of being able to lock or vary the angle of the rollers on a mecanum wheel to increase performance. That would be an awesome, award worthy accomplishment by a FIRST team that I hope someone will at least attempt in this or future seasons.
  #47   Spotlight this post!
Unread 09-01-2008, 15:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Or you could angle omni wheels at, say, 30 degrees to the long axis of the robot instead of 45 to achieve the same effect, right?
  #48   Spotlight this post!
Unread 10-01-2008, 01:18
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
I'm kinda new with plastics, but why would you use UHMW for a chassis?
It would be virtually unbreakable, but isn't it flexible? And I though UHMW was used for more high friction situations(like chain tensioners)?
  #49   Spotlight this post!
Unread 10-01-2008, 11:00
MrForbes's Avatar
AKA: Jim
A flexible chassis is a design feature of a holonomic drive robot...helps keep all the wheels on the ground, so it will be more likely to drive the direction you intend it to.
pic: vex omni drive 1902_Battery_SGT FIRST Tech Challenge 6 28-05-2006 17:55
Omni-Wheel Design fightoplankton Technical Discussion 7 08-01-2006 23:49
pic: Dual omni-wheel Richard Wallace Extra Discussion 17 05-12-2005 10:38
pic: Omni Idea Sachiel7 Extra Discussion 4 31-01-2005 12:46
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
