Go to Post (Don't you hate it...) "when... no more buttons can fit onto your clothing at competitions?" - mcb [more]
Unread 06-01-2008, 16:17
beemgruem's Avatar
beemgruem beemgruem is offline
AKA: Begüm
FRC #2905 (Sultans of Turkey)
beemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to beholdbeemgruem is a splendid one to behold
Power Distribution Block..
Hey guys!
We start to build the power distribution part and I am wondering how to put together the black to red with the grey partS?? Did anyone make it?? Do we need extra board to screw drive on?
Unread 06-01-2008, 16:20
Nate Laverdure's Avatar
FRC #2363
Re: Power Distribution Block..
From Section 10 of the manual:
Unread 06-01-2008, 16:24
beemgruem's Avatar
AKA: Begüm
thanks
Unread 06-01-2008, 16:33
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
and you dont have to use all the red and black ones, dont waste weight putting them on if you dont need all of them.
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 06-01-2008, 16:50
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Since not using all of the red and black blocks requires cutting down the yellow center jumpers, I'd suggest waiting to make that decision until you're absolutely sure how many blocks you'll need. I seem to recall that a few teams that made late design changes last year had to reorder/scrounge a full-length jumper at the last minute.
Unread 06-01-2008, 16:54
ubermeister's Avatar
ubermeister ubermeister is offline
AKA: Eric VA
ubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the roughubermeister is a jewel in the rough
And of course, remember to tighten all your screws up before every match- I'm surprised they stuck with these blocks this year, seeing as all the loose wire problems they had last year.
Unread 06-01-2008, 20:29
BQuennell's Avatar
BQuennell BQuennell is offline
Electronics Mentor
FRC #1388 (Eagle Robotics)
BQuennell has a spectacular aura aboutBQuennell has a spectacular aura about
Send a message via AIM to BQuennell Send a message via MSN to BQuennell
That was us last year, and belive me that trying to find a new one was not too easy until we excanged one at a reagonal. Try to keep the PDB intact until youve come to the final design of the bot, and that can mean changes at a reagonal too.
Eagle Robotics Team 1388
It's Hammertime!
2005 SAC Engineering Inspiration Award
2006 SAC J&J Sportsmanship Award
2007 LA Xerox Creativity Award
2008 SD Xerox Creativity Award
2008 SAC Regional Finalist
2008 SAC Engineering Inspiration
Unread 09-01-2008, 23:21
1337Nerd's Avatar
1337Nerd 1337Nerd is offline
Head Videographer/Electrical Guy
FRC #1006 (Fast Eddie)
Team Role: Communications
1337Nerd is a glorious beacon of light1337Nerd is a glorious beacon of light1337Nerd is a glorious beacon of light1337Nerd is a glorious beacon of light1337Nerd is a glorious beacon of light
These new power distibution blocks suck. They use unnessecary room and don't secure wires very well. Plus you have to cut down the yellow parts if you're only using two or three blocks. Really pointless. I miss the old one.
Unread 09-01-2008, 23:27
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
This post
http://www.chiefdelphi.com/forums/sh...53&postcount=5
offers free, easy solutions to your loose wiring problems.
Unread 09-01-2008, 23:59
DonRotolo's Avatar
Back to humble
FRC #0832
I agree with Squirrel: If you use them correctly, they work perfectly, and if you use them incorrectly, do you wonder why they don't work right?
Careful with that They, lad.
Don
Unread 10-01-2008, 01:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
See that's just the point though. As far as I know, these are not designed for the application they are being used in. Traditionally you see these things in rather static environments not subject to the kind of vibrations we see in FRC. I'd say FIRST is using them incorrectly.
Unread 10-01-2008, 01:38
Smaug's Avatar
Smaug Smaug is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Electrical
Smaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the roughSmaug is a jewel in the rough
a thing team 675 did that seamed to help was solder the wires before you put them in the distribution block. the solder keeps the wire is one piece instead of spreading out when pressure is applied and in turn falling out of the hole.
If it isn't broken, Fix it till it is ~ Baker
Unread 10-01-2008, 01:47
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
I'm going to go with the new PDBs suck argument. They were a real pain to use last year. They really were. But I'm not as mad about the PDBs as I am about the fact that I cant use the 40/30/20 breaker panel that I love so much.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 10-01-2008, 02:16
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Our team ordered and used the old power distribution block last year from a few years ago.
Are we still allowed to use those? They are COTS items, so I think we can.
Unread 10-01-2008, 09:11
Working backwards...
No the rules state you must use the Power Distribution Block. You had to use it last year as well. There are no substitutes. See R50, it is too lengthy to quote here.
I miss the IFI breaker panel as well.
This block is an industry standard component and as Sanddrag has pointed out, they are most often used in static (non-moving) environments. It is for that reason, I recommend that all teams secure the wiring with tywraps (wire ties) near the block. Wires that can't move won't transmit the movement to the block.
Never tin (apply solder) for wires used in any type of clamp or crimp prior to insertion. For this block in particular, the wire will not conform to the terminal as the screw is tightened and therefore you will increase the surface resistance of the connection. Resistance means heat and current reduction. Heat will cause the terminals to expand making the situation worse, not better.
Squirrel thanks for the link, I didn't think people ever read my posts.
Yes you can eliminate the unused blocks and cut the jumper, but you never know when you might need to add something back.
Stripping less than 5/8" of insulation will cause the wire to be pushed out of the terminal when you tighten the screws.
Question:Power Distribution Block Pavan Dave Electrical 35 20-03-2007 20:10
Power distribution block mounting Kapao69x5 Electrical 22 16-02-2007 13:55
Power distribution Block? Pontchartrain Electrical 3 27-01-2006 07:30
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Power Distribution Block DukesElectrical General Forum 0 09-02-2004 23:48
