Go to Post Chuck Norris can be the human player and throw a Poof ball into the 3 point goal and it counts. - Andy Baker [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:07
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: rules and chiefdelphi.com to the rescue!!!
Posted by Bill Beatty.
Other on team #71, Team Hammond, from Team Hammond.
Posted on 10/28/99 7:23 AM MST
In Reply to: Re: rules and chiefdelphi.com to the rescue!!! posted by Andy Grady on 10/27/99 7:48 PM MST:
Andy
The final gear on the output shaft(?) is the problem. In the elimination rounds we were only getting a few matches out of a gear. We came up with a replacment rim made out of aluminum that fit into the case without modification. After cleaning out the gob of grease from inside the case there was no increase in weight.
BTW, Joe won't believe this, but there are two different motor pinions and gear cases available. One has 16 teeth on motor pinion, other has 19. If you want your kid to have the hotest FP car on the block, make sure you get the high speed pinion
Bill Beatty
[IMG] code is Off
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
Module 7 gear -- fischer price motor archiver 2001 6 23-06-2002 22:55
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
Fischer Price Part Number? bmusser Technical Discussion 0 02-02-2002 12:26
fischer price motors Paul Marshall Motors 4 12-10-2001 09:44
