Go to Post Now I watch students walk through the halls together as Robotics members. - MysterE [more]
Unread 10-01-2008, 01:04
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Axles/Spacers
what kind of spacers do you guys use on your axles?
our team has looked at the tips and good practices manual where they advise teams to use sleeves and washers.
if you use sleeves, can you please provide me with a supplier's website
thank you
Unread 10-01-2008, 01:19
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Axles/Spacers
Search McMaster Carr for "Set Screw Shaft Collars".
I think they're far easier to use than washers. Simply slide them where you want them, and tighten them down (One of the few acceptable uses for set screws )
2001-2004: Team 100
2006-Present: Team 254
Unread 10-01-2008, 01:32
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Axles/Spacers
I prefer the split kind so you can install and remove them without pulling the axle out. E-clips are another option.
Unread 10-01-2008, 01:39
M4 Sherman's Avatar
M4 Sherman M4 Sherman is offline
FRC #1662 (Raptor Force Engineering)
M4 Sherman is an unknown quantity at this point
Re: Axles/Spacers
1/16" wall aluminum tubing works pretty good.
Unread 10-01-2008, 08:05
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Axles/Spacers
You can always check your local hardware store. The Ace hardware by us has shaft collars and aluminum tubing in stock. It might cost a little more, but you don't have to wait for shipping.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 10-01-2008, 08:22
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: Axles/Spacers
We found some copper tubing in the basement that fits our 1/2" axles alright.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 10-01-2008, 13:56
in between teams
AKA: Luke Van Oort
Re: Axles/Spacers
As you can see from above, many materials are successful. Sanddag's suggestion is probably the easiest to work with, and M4 Sherman's is likely the cheapest of those already proposed (PVC would be cheaper still though). My team has never gone the shaft collar route (recently that is, I think some of our old robots might use them), but we've done thin-wall aluminum tubing, steel tubing, and PVC pipes. You know what we have learned? Material choice doesn't really matter much. What is more important is making sure that they are the right length and that their ends are not cut at an angle. That is why we aren't going to go with steel again--too hard to cut accurately with our tools.
Team 1219: 2009 - Mentor
Keyed Axles aznium Kit & Additional Hardware 4 03-02-2006 19:24
axles? SPARKY1688 Kit & Additional Hardware 1 15-01-2005 01:26
Spacers srjjs Kit & Additional Hardware 6 13-01-2004 20:49
Spacers in FIRST gearboxes Dr.Bot Motors 11 02-02-2003 20:49
axles maxgebhardt Kit & Additional Hardware 1 15-01-2003 19:00
